Thread: ERV effectiveness at ambient temperatures
    Oct 2007
    Hi,
    The data on hvi.org lists efficiencies of ERVs at cooling and heating loads. What I'd like to know is how efficient i can expect them to be at transfering moisture when the interior and exterior temperatures are close (i.e no heat exchange being done).
    Apr 2002
    on the renewaire type probably 20 to 25%
    on the ones with the wheels probably twice that
    http://www.ductstrap.com/
    Oct 2007
    Quote Originally Posted by Carnak View Post
    Hmmm. I callled vanEE yesterday for information on their Gold ERV and they could not provide an answer. I suspect it might be in the same range, depending on the humidity differential.
    As I mentionned in other posts, my main issue is with high humidity in spring/summer/fall. I know that I need a dehumidifer but was wondering if an ERV would help as well.
    The temperature differential between inside and outside for most of those three seasons would be a maximum of 10C on the hotest summer days. I probably would not benefit too much from the heat exchange of an ERV and if the humidity exchange is only 25%, I think I might be better off with a ventilating dehumidifer only.
    Apr 2002
    Quote Originally Posted by sancyk View Post
    vanEE uses a wheel
    Oct 2007
    vanEE uses a wheel
    I'm fairly certain that the vanEE Gold 1001 ERV uses a paper core (interchangeable with the HRV core if required).
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
