Results 14 to 19 of 19
    Feb 2005
    Quote Originally Posted by kdocsr05 View Post
    Lets put it this way. I have several facilities running CBAS and deal with Computrols weekly
    another question for you:
    Does this computrols interface also mean that I could theoretically put an 8X, put my N2 bus onto it and then program it to be BACnet/IP as well. Then poke it through another BACnet software to get some N2 data that way, directly from 8X controller?
    Amarillo by mornin'
    Quote Originally Posted by amigo View Post
    Good question! Also, would you have to purchase CBAS to do this or use their "free" config tools?
    EDIT: Are you limited on integration points?
    "It's not that I'm smart, it's that I stay with the problem longer”
    Albert Einstein
    Feb 2005
    Edmonton, AB Canada
    Good day kdocsr05
    Given that you have been using the Computrol 8X devices, can you answer the following?
    1.Can you tell us how many N2 devices can be supported by the 8X device? Their website and datasheet do not seem to say this?
    2. What is the approximate cost of the 8X device?
    Lastly, what is interesting is that the 8X spec sheet states that the 8X is based on the Intel 386 processor operating at 25Mhz... which is pretty impressive given the capabilities and limited resources of this device. Further, I did not even think that you could even buy 386 processors (embedded) anymore.
    Cheers,
    Sam
    NY NY
    Hello s2sam
    The 8x as you refer to is a just the controller. You would need the CBAS front end to establish the interface you desire. I will be involved commisioning two 32x controllers early next week. I will talk to the controls programer, present your questions to the source and get back to you then.
    Regards
    Feb 2005
    Edmonton, AB Canada
    Hello s2sam
    Regards
    Good day kdocsr05,
    Sounds good! I look forward to the info.
    As for the CBAS and its N2 functionality, this is making more sense, as the controllers appeared to have a limited amount of on-board resources (not a lot of on-board memory) to accommodate a fully loaded N2 trunk on its own.
    Thanks in advance for the info!
    Cheers,
    Sam
    Jun 2006
    Athens Greece
    Hello guys,
    does anybody know what Computrols request to become a dealer of them?
    I poped a question to their site but still waitting.
    By the way I am located in Greece...
    Thanx
