Results 14 to 19 of 19
Thread: Computrols' JCI Interface
10-29-2009, 04:50 PM #14
another question for you:
Does this computrols interface also mean that I could theoretically put an 8X, put my N2 bus onto it and then program it to be BACnet/IP as well. Then poke it through another BACnet software to get some N2 data that way, directly from 8X controller?
10-29-2009, 05:18 PM #15
"If you can't explain it simply, you don't understand it well enough
Albert Einstein
"Don't you just love when the flames burn off the wiring schematic?" hvacvegas-HTALK member
On Monday, not even the chickens lay eggs...
10-29-2009, 06:07 PM #16
- Feb 2005
- Edmonton, AB Canada
- 520
Good day kdocsr05
Given that you have been using the Computrol 8X devices, can you answer the following?
1.Can you tell us how many N2 devices can be supported by the 8X device? Their website and datasheet do not seem to say this?
2. What is the approximate cost of the 8X device?
Lastly, what is interesting is that the 8X spec sheet states that the 8X is based on the Intel 386 processor operating at 25Mhz... which is pretty impressive given the capabilities and limited resources of this device. Further, I did not even think that you could even buy 386 processors (embedded) anymore.
Cheers,
Sam
10-30-2009, 12:27 AM #17
Hello s2sam
The 8x as you refer to is a just the controller. You would need the CBAS front end to establish the interface you desire. I will be involved commisioning two 32x controllers early next week. I will talk to the controls programer, present your questions to the source and get back to you then.
Regards
10-30-2009, 12:58 AM #18
- Feb 2005
- 520
Good day kdocsr05,
Sounds good! I look forward to the info.
As for the CBAS and its N2 functionality, this is making more sense, as the controllers appeared to have a limited amount of on-board resources (not a lot of on-board memory) to accommodate a fully loaded N2 trunk on its own.
Thanks in advance for the info!
Cheers,
Sam
10-30-2009, 09:13 AM #19
- Jun 2006
- Athens Greece
- 108
Hello guys,
does anybody know what Computrols request to become a dealer of them?
I poped a question to their site but still waitting.
By the way I am located in Greece...
Thanx
