+ Reply to Thread
Results 1 to 20 of 21
Thread: Plumbers gas pipe
    Outside The Motor City
    Plumbers gas pipe
    this was the only 1 out of 8 units piped with a sediment trap.
    Attachment 54062
    Jul 2009
    Dont see that one catching much sediment. I'm wondering if it isnt a pressure test point or a line purge point???
    Howell, Michigan
    unreal, it blows me away as to how stupid some installers are.
    Sterling Heights, MI
    Nice new black pipe going into a rusty piece at unit. Afterall, those darn reducing tees should come with instructions. Or maybe they couldn't read the Chinese directions.
    Better Service Through Knowledge...
    RSES, The HVACR Training Authority. www.rses.org
    UWUA Local 223
    S.E. Pa
    Exclamation improper piping
    First of all, the tee shown is not a sediment trap. In order to be considered a sediment trap, it must have a 90* vertical axis so the leg functions as a trash can using gravity.
    That pipe must be protected from the element such as painting or wrapping.
    The pipe is inadequately supported.
    The issue of sed. traps outdoors is controverial. Some AHJs prohibit it fearing condensate freezing while others don't see liquid condensate but do see particulate foreign matter that does get catch in the traps. The code just says all gas utilization equipment must have sed. traps except fireplaces.
    Hearthman
    lancaster ca
    whats with the condensate or lack there of???
    Aug 2008
    Quote Originally Posted by houtonjr View Post
    NAT. gas has alot of moisture in it last winter here in okl. I had alot of reg. freeze up no gas to the buildings so you can see how the sed. trap could freeze and rupture.
    lancaster ca
    Quote Originally Posted by mike robinson View Post
    i was refering to the condensate line not being there they put a P-trap but nothing else
    Indiana
    Normal commercial rooftop installation of condensate drain. nothing more is needed, water runs onto roof just as rain would fall onto it.
    give the guy some credit
    the cut-off is
    upstream
    of the union & tee.
    Jul 2009
    In a mechanical room....
    In Florida we have to drain condensate off of the roof at least in a roof scuffer or it will not pass code.
    Up here most units just have the ptrap off the condensate dripping onto the roof. Sometimes a patio block will be put under it to dissipate the water so its not constantly hitting the same point on the roof.
    Northeast Wisconsin
    Same here. Just pipe it out onto the roof appropriately to meet the manufacturer requirements and nothing more. From time to time the customer or we run a longer drain to a particular point for various reasons. 99% are like the unit pictured in this thread.
  14. #14
    Jul 2009
    Plant City, Florida
    Quote Originally Posted by chrishvacman View Post
    It is called a Scupper.
    When I took the test for my Certified Plumbers license there were a couple of questions on the exam about the minimum size of Roof Scuppers, a few of the guys I was talking to after the exam didn't know what they were.
  15. #15
    Jul 2009
    I was trying to remember how to spell Scupper thank you
  16. #16
    burlington county n.j.
    Quote Originally Posted by hvac248 View Post
    Attachment 54062
    at least it won't freeze...
  17. #17
    Okieville
    I'm willing to bet that the installer ran out of 90's and used a tee and a cap to finish it up.
  18. #18
    New England
    that drip leg is going to do a whole lot of nothing!
  19. #19
    lancaster ca
    Quote Originally Posted by yellowirenut View Post
    that wont pass inspection around here if they dont go off the roof.... some of the older inspectors wanna see copper still
  20. #20
    Denver, CO
    Thanks for the chuckle, thats a good one.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
