    Oct 2009
    cost effective measurement points
    What is the most cost effective way to measure temps/pressure on 3/4 and 1" HDPE pipe. I know about balancing valves but these are costly. I would like to have just a ball valve with a TP port or just a TP port with HDPE connections.
    What have others used. I am not going to put this on every system, but will have a couple on HP coil in every system.
    You don't need to give me prices , just appreciate ideas.
    Thanks for feedback.
    GoneGeo
    Berkley, MI
    Depending on where you're looking to locate the P/T port I'd think you could either locate it right at the heat pumps with a brass 90 that has an integral P/T port. You could also install an inline "T" with a brass adapter that would accept a P/T port.
    Jul 2003
    The Isle of Long
    I use brass fittings (tees, nipples, reducers, boiler drains, PT ports, etc) at the heat pump and then break down to whatever piping is being used (s40,s80, L). Have found it easier to work with brass fittings than to use PVC or Copper fittings at the heat pump connections. The brass gives you a strong connection where the PVC won't.
    Learning is a lifelong process
    Dec 2008
    South Jordan Utah
    You can buy HDPE tees with a brass thread on one leg and then just thread in the P/T port.
    The tees are available at Geothermal Supply Co and other suppliers.
    Dewayne Dean
    www.palacegeothermal.com
    See my live system data here:
    We Heat and Cool with Dirt
    May 2005
    Quote Originally Posted by geodean View Post
    This is what I used. They worked out very well. Solid construction.
