View Poll Results: Fully modulating gas furnace, worth it? or Dual Stage w/variable speed blower enough
Voters
4. You may not vote on this poll
  • Modulating all the way - Rolls Royce of furnaces worth the cost
    4 100.00%
  • Don't waste your money - Dual Stage Furnace provides 99% of what you need.
    0 0%
  • Their both a waste - Single Stage with a variable speed blower will do the trick.
    0 0%
Results 1 to 7 of 7
    Oct 2009
    Los Angeles
    Fully Modulating Gas Furnace- Worth it or not?
    Fully Modulating Gas Furnace- Worth it or is getting a variable speed dual stage enough?
    Colorado flatland native
    In LA?
    Walter Matthau
    Oct 2009
    Los Angeles
    Quote Originally Posted by spotts View Post
    In LA?
    you'd be surprised. Depending where you live it can get near freezing for 4 months out of the year. Sure, it's not Minnesota but the heat is on 4-5 months out of the year.
    But, it's a different answer in diff. parts of the country. Here in Colorado, we get 325 sunny days a year. Temp can go from 0 to 60 in a day. Can be below 0 for days. Have seen -24, and 110. Modulating would be great......... In LA, I would spend the money on a nice 95% with a high efff. heat pump. But thats a guess, I dont live there. You got money burnin a hole in yer pocket? You want a fancy furnace, by all means, buy one!
    Walter Matthau
    Illinois
    I would say modulating all the way. It is the most ideal thing to get for comfort and efficiency.
    Emerald Coast
    Exactly!
    Do not attempt vast projects with
    half vast experience and ideas.
    Mod with a stat that tells the furnace what to do based on the needs of the house, room temp, set temp, etc. No timers, no algorithms guessing, no 2 stage stats. Modulating stats.
    Otherwise a good 2 or 3 stage with 2 stage or communicating control respectively.
