Results 1 to 8 of 8
    windy city
    McQuay Machine Charge
    Co-worker is on a PEH126JB, s/n 5RB0300100, fixing leaks. Anyone got machine refrigerant charge? Converted to R-134a, believe to be 1700#. Any help would be appreciated.
    Jul 2009
    In a mechanical room....
    Why trust charge instead of superheat and subcooling esp if it is a retro?
    windy city
    i understand how to charge a machine. he's on a quoted job which has to be closed out, and with the temps now, he won't be able to wind her up.
    also - the original tags were removed, new tags don't state amount.
    Jul 2009
    I knew you wouldn't ask a question like that unless you had a good reason lol. I do not have the answer to your question, however my office in fl is across the street from mcquays office I can toilet paper their office if they can't answer your question for ya.
    windy city
    Western Wa
    If the conversion was done by McQuay Service, there would probably be a record of the engineering process, in the Staunton office. Many also included a gear ratio change.
    At least, you could get the original R-12 charge, and then guess pretty close from there.
    God Bless the USA
    windy city
    Quote Originally Posted by Randy S. View Post
    The way i got it from my dispatcher was the tech was in touch with the factory, and that conversation didn't 'work out' too good. I was asked if i can find out. (I have a mountain of paper, and you gentlemen). Thought there mite be someone out there with a 'cheat' sheet.
    I don't know what was upgraded on the conversion.
    But anyways, thank you all for the responses.
    The Great country of Texas
    I did many McQuay conversions and the charge usually was 20% more than the R-12 charge. Put the thing at full load, make sure you have 6-12 degrees of subcooling, check the discharge superheat without the liquid injection on, should have 15% DGSH at full load with good subcooling.
    Adjust the TXV pilot valve accordingly to achive.
    "I'm from Texas, what country are you from?"
