Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 51
  1. #27
    Rochester NY
    Instead of putting plastic in the ground and using water as an intermediate medium of heat transfer, you put copper in the ground and go direct. Hence direct exchange.
    Requires much less drilling, and a lot of refrigerant.
  2. #28
    Mar 2006
    Denver/Boulder
    Quote Originally Posted by tedkidd View Post
    yes, yes, and yes.
    What lies behind us and what lies before us are small matters compared to what lies within us.
    Two pressures, four temperatures = SUCCESS!
    Boulder Heating Contractor
  3. #29
    Aug 2001
    forney texas
    Quote Originally Posted by darctangent View Post
    yes, yes, and yes.
    Ok, I see where you are coming from. Next question. Why not just break out the torch and repair the leak in the coil?
  4. #30
    Mar 2006
    Denver/Boulder
    Quote Originally Posted by acmanko View Post
    you are a tough crowd.
  5. #31
    Rochester NY
    Bring a big recovery tank!
  6. #32
    Mar 2006
    Denver/Boulder
    I'll take the cost of 2 jugs of refrigerant over the cost of drilling 3-5 times as much. I can also use better grout for better heat transfer.
  7. #33
    Interesting. I have heard of this but have never seen a system. What size of copper line do you use and how many feet per ton? Say on a horizontal system. What are the cop"s? How do you work out your charge - based on length of pipe in the ground?
  8. #34
    Rochester NY
    Darctangent, are you being argumentative or trying to educate?
    If you are trying to educate it would be great if your posts had a bit more substance. For example, you could state that a direct exchange system uses 4lb + 4lb per ton, or a discussion about enhanced thermal grout/silica mixes and what you mean about your ability to use "better grout".
    Without that detail you might simply appear argumentative. That's my
    Quote Originally Posted by can2man View Post
    I believe you have 70 ft cores with 1-2 per ton. Not really set up for trenches yet, but they are experimenting with it in Tennessee, along with using the foundation perimeter on new homes. COP's are available at ahri I believe.
  9. #35
    Thank you
  10. #36
    Mar 2006
    Denver/Boulder
    I've got to get ready for an install tomorrow so this will be a little brief, but I'll try to cover some territory here.
    It depends on the application, but 3/8 & 1/2 or 5/8 are typical. When it comes to length, again system design will vary, but with vertical and diagonal bore holes you are talking about (1)100ft bore per ton with 100ft down, 100ft up so 200ft of tubing per ton, plus the copper to get back to the heat pump. I have never had a system that was designed for horizontal loops, but as I recall there are similar figures for that as well. COPs vary dependent on ground temp and soil conditions, but about 3 to 4.5. Nominal charge is about 7 lbs/ per ton on forced air with Domestic hot water, less on hydronic only systems. Charge is a little hard to explain, but very very easy to do. It relates to the metering system which is proprietary to Eathlinked. Suffice to say the metering system is like the old school refrigerators with a float arm in a reservoir of refrigerant. It sounds odd by modern thinking, but it's actually very efficient.- that's just part of it though- it's actually quite hard to explain in print only.
    Not trying to argue at all. If you read back to where this all started, I was simply pointing out that there is more to geothermal/ground source than water based systems. Then I got multiple responses essentially denying what I was saying. If there was an argument, it was about the requirement of using water in ground source systems. If you read back, I pointed out that I thought there were advantages and disadvantages to water source (as apposed to DX) Neither technology is perfect.
    On grout, bentonite based grout has a really nasty habit of stratifying in the bore hole causing the grout to fall away from the tubing and therefore poor thermal conductivity. My last two jobs I've used a cementitious grout called "supergrout"
    Another point- as I referenced earlier, horizontal loops do exist, and in some areas are the preferred method of install, but that in not the case in Colorado.
    All of this is dependant on the design laid out by the manufacturer, in this case Eathlinked.
  11. #37
    Rochester NY
    I'm no better at avoiding getting sucked in. Key is attempt to just give good information, particularly in response to ignorant and argumentative posts. Read Beenthere's stuff, he's usually really good at this (and some of the other guys).
    To some extent this is like kindergarten, everybody making noise wanting attention, but much is just noise without substance. People reading quickly sort through a lot of chaff to find good seeds. Only so much can stick (why fill the grey up with garbage, right?). The childish posts tend to blow away like deleting junk mail.
    Just thinking a lot of your stuff has seeds. Don't let others suck you into posting chaff.
  12. #38
    Michigan
    IF YOU LIVE IN MICHIGAN-its not worth the trouble
    I worked for a company that sold waterfurnace and I think it was called international units. They got something back in arounds 1500 tax credit. The systems worked great once tuned in and would have a pay back of 100% in 11 years. But WOW the up front cost, did I say WOW, we did pond, horizontal earth closed loop, vertical well closed loop, and pump and dump.
    Here is what the fancy brochures leave out:
    Your yard / landscaping will need a complete overhaul once the heavy equipment is out, so if you can aford a GEO chances are you will at least have to replace about 10 - 15 grand in landscaping.
    Well drilling company - about 2000 a hole 4-6 in at 150 feet down.
    Dive team for pond loop - about 120 an hour.
    Heavy equipment rental is around 1600 a week for a loader and backhoe.
    Glycol - lots of the alien slime.
    A mile of sheet metal for your air handling units.
    Lots and lots of time for tuning.
    2 in diameter pipes punching through your basement wall (real fun to work with especially when they are cold).
    The actual water to air units weigh a lot so heavy some of the bigger members of your crew handy.
    Low end Geo for a small home was about 30-40,000 dollars at 2500-4000 ft squared and about 65-120,000 dollars at 5000-12000 ft squared homes
    Just wanted to let you know some of the un-glorious things about GEO, it is a great idea, but not in the north for small companies trying to profit. Just a headache, schools make it seem great (mine did), but unless you are out trying to sell people this stuff and trying to put it in then I would not waste my time with my nose in a book trying to memorize calculations and practicing design principals. You need to find a local that does it, volunteer to help on a system and get your own perspective, I know after getting out of the HVACR design program at school and actually doing it I was left with a sour taste.
    But IGSHPA is the source for all GEO.
  13. #39
    Mar 2006
    Denver/Boulder
    Quote Originally Posted by durussel78 View Post
    have you read this thread or not?
