Results 14 to 26 of 51
    Mar 2006
    Denver/Boulder
    Quote Originally Posted by acmanko View Post
    There is only one difference in an air to air HP and a geothermal HP and that is the medium used to reject heat, which is water. Other than that, they are the same puppy.
    not always.
    You water source guys really do have a one track mind.
    What lies behind us and what lies before us are small matters compared to what lies within us.
    Two pressures, four temperatures = SUCCESS!
    Boulder Heating Contractor
    For Consumers:
    For HVACR Professionals:
    Aug 2001
    forney texas
    Quote Originally Posted by darctangent View Post
    not always.
    Of course they are. For geothermal, you need to know pumps, water temp in and water temp out. The refrigerant changes state depending on temperature. it could care less if the temps are from water or air.
    Mar 2006
    Denver/Boulder
    I do geo, I use no water (unless I'm heating domestic or hydronic water)
    Like I said, one track mind.
    Those other manufacturers like to deny the existence of any technology outside of their own.
    there are pros and cons to using water. I do without just fine. IGSHPA and friends have got you guys brainwashed.
    For Consumers:
    Aug 2001
    forney texas
    So what fluid do you use for the loop?
    Mar 2006
    Denver/Boulder
    fluid? not exactly.
    R-22
    r-407c
    r-410a
    it's called "DX" or "direct exchange"
    Horizontal loop fields, vertical and diagonal bore holes.
    For Consumers:
    Aug 2001
    forney texas
    fluid? not exactly.
    R-22
    r-407c
    r-410a
    so what's the majic fluid that goes into the Horizontal loop fields, vertical and diagonal bore holes.
    its called DX or Direct expansion.
    Mar 2006
    Denver/Boulder
    same answer.
    sorry, but you aren't listening.
    r-22
    r-407c
    r-410a
    For Consumers:
    Mar 2006
    Denver/Boulder
    If the light isn't going on by now, I'm going to start worrying.
    For Consumers:
    Mar 2006
    Denver/Boulder
    no, it's called DX or direct exchange.
    But, hey we all make mistakes.
    you're thinking of the other end of the system.
    Like I said, everybody thinks they already know what's out there.
    Mouth open, ears closed,
    instead of the other way around.
    For Consumers:
    Aug 2001
    forney texas
    same answer.
    r-22
    r-407c
    r-410a
    I can't think of a loop that has refrigerant in it. refrigerant is in the AC system , the loop that makes it geothermal has water in it.
    Mar 2006
    Denver/Boulder
    What do you call the refrigerant cycle? Isn't that a loop with a pump in the middle?
    For Consumers:
    Aug 2001
    forney texas
    Yes, but that has nothing to do with a unit being geothermal. You can get heat from the air for a regular Heat Pump or heat from the ground with a Geothermal Heat Pump. Water is whats used in a geothermal system to transfer the heat from the ground via a pump and a tube in a tube condenser.
    Mar 2006
    Denver/Boulder
    Oh lord.
    ok, envision this:
    you've got a conventional Heat Pump, but it's got a leak in the condenser coil.
    Oh, darnit, what to do?
    what to do, what to do?
    Whatever could we do?
    hmmm....
    How about this?
    we dig a trench in the ground and lay tubing in the trench, then we fill in the trench. we then connect the tubing to the condenser where it used to connect to the old condenser coil.
    now, the ground is the condenser. see?
    refrigerant travels through the "loop" or the "condenser coil" only now it's in the ground.
    no water.
    It's a little simplified, but that's how it all started.
    How is that NOT "geothermal" ?
    For Consumers:
