    Oct 2009
    The dinosaur is gone
    Today I change a Lennox g8137 furnace> the damm thing had the original gas valve and other controls. Only the blower motor was changed.
    Serial number was 66-12. Now this is well befor my time, havent even seen a g8 for 12 years and am not sure if the 66 is the year.
    I also changed the Honneywell T90 stat with the lennox name on it.
    Here is the catch. no visible cracks in the heat exchaner in the normal locations. If it was a g12 it would have been done.
    Home owner opted for a 80% but its still going to save some decent money
    real steel in the HX..............not that crappy stamped stuff
    Bay Area, CA
    I still service gravity or retrofitted gravity furnaces that are 2-3 times older then me, built in the early 40's cant crack a steel heat exchanger it seems. Cost an arm and a leg to run too.
    Global Warming or: None like it hot
    No pleasure, no rapture, no exquisite sin greater... than central air. -Dogma
    I don't know
    I always thought the G12 was steel.
    G8s were manufactured in canada until the early 90s. (design probably revised a few times - larger blowers for a/c and electronic ignition)
    Oct 2009
    standing pilot, belt drive on this baby.
    lennox would be so proud
