    Nov 2001
    gas valve convertion
    help on coverting a Eurosit 630 thermostatic gas valve from Nat. to LP
    Nov 2009
    Most fireplace manufacturers have conversion kits you can purchase that come with instructions. Constact a dealer/distributor to see if this is the case
    Northeast Ohio
    May not be convertible, you will need to check with the manufacturer. Alot of the valves with the themostatic expansion cap tube can't be converted.
    DEM
    Virginia
    Those valves usually come on ventfree gas logs. Is this on a VF? If it is, do not attempt to convert it !!!!
