+ Reply to Thread
Results 1 to 7 of 7
Thread: 220V or Nat Gas line - what's harder?
    Oct 2009
    Los Angeles
    Trying to decide between airhandler & heat pump VS. gas furnace & a/c condenser, set up.
    Old 1920's home no nat gas lines in attic or 220V. Need heat and A/C in second story of 2 story home. What is harder (more expensive) to set up there, Nat gas line with vent pipe, or 220V electricity line from downstairs?
    Madison, Wisconsin
    Well, not being there to actually see the situation makes it hard to give a educated opinion, but here is my 2 cents. With the gas system you still need electric, while the heat pump dosent need any gas...
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Denver, CO
    In LA can you get by with just a heat pump without backup gas or electric heat?
    Oct 2001
    go with a professionally install on a HP,and the correct charge tight duct work.you'll be OK 40F in LA with rain is considered cold out there
    "when in doubt...jump it out" http://www.youtube.com/watch?v=U1qEZHhJubY
    Oct 2009
    Los Angeles
    Quote Originally Posted by Wheelbaron View Post
    yes this is true, but my understading is that the furnace can run on an existing 110v, while the airhandler is going to need 220v which doesn't exist in the attic right now, which is why i am curious if you guys know what's harder to install the electrical or the gas line to an attic?
    Jan 2001
    With either gas or heat pump you are going to have more "lines" going up there than a wire or gas line.
    You are going to have refrigerant lines and drain lines for the air conditioning and heating coil.
    If it were me I would just get a heat pump.
    You can run the 220 wire up to the attic with the refrigerant lines and the drain lines. Of course you could do the same with a gas line... but in the end I believe a HP would be cheaper to install.
    Plus you dont have a vent thru the roof....or a vent and a combustion air intake.
    and of course....not there to see the job..so this is just my opinion based on very general information.
    Oct 2009
    Los Angeles
    Quote Originally Posted by corny View Post
    This is the way I was leaning. Since the upstairs heat is not really an issue, I care more about A/C on the second floor. Thanks everyone for your responses, super helpful!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
