Thread: heatmaster log problem
10-17-2009, 05:33 PM #1
I am working on a set of logs that i can get the pilot to light but when i try to turn on to burners it cuts completly down. Shuts pilot off, i can hear the valve. It has a thermocouple and thermopile,thermocouple working because pilot will hold. Thermopile seems to check out but could be bad. I just do not think if it was thermopile it would cut pilot off.
10-18-2009, 06:46 AM #2
- Jul 2006
- Virginia
- 378
What happens to the pilot when you turn on the main burner? Does it become instantly smaller?Is the pilot yellow and lazy, or blue and strong?
10-18-2009, 01:42 PM #3
Forum rules prevent DIY advice here. However, I can suggest a comprehensive approach to service including inlet gas pressures conducted by a qualified technician. If your piping is undersized, it would manifest in the way you describe.
HearthmanKeep the fire inside the fireplace.
