Results 1 to 9 of 9
    Mar 2006
    Wakulla County, Florida
    York YCAS250 Microprocessor Help
    Installing a new board in chiller. I tried to program the 21 different menus and can find only 14. The chiller will run a comp for about a min. and then go off on over amp because one of the menus I cant find is motor current setting. Do I need to set a dip switch to get to these additional 7 menus? I have used the password given in the IOM (7396) and also the York password (9675). Still cant find.
    Dec 2006
    There is a another secret code and i am trying to remember it as I type. This code will get you into the screen you need, i then right down the specs on the inside of the panel. Try 5244??? Get right back to me and let me know, i'm starring at my phone trying to remember.
    Dec 2006
    or try 5422, i am real close.
    Dec 2006
    try 5144, i keep looking at the numbers on the phone to remember the sequence.
    Mar 2006
    I got rained off the job. I will let you know if any of those worked. Thanks for the info.
    Dec 2008
    Dixiana, AL
    Mar 2006
    We got a winner. 5144. Thanks for the info guys.
    Somewhere in the world.
    The code Klove gave is the correct one if you changed the micro board or expansion module you will need the set the motor protection info. back up as you are already experiencing problems due to that.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Dec 2006
    Right on!!! Glad it worked!!!
