Results 1 to 6 of 6
    Dec 2009
    G-Wire on a stat
    I'm assuming "G" on a thermostat is supposed to go to 24V AC when the heat kicks on, but it doesn't. When I'm at the thermostat and switch the fan on, then it reads 24V.
    Regardless, the blower still turns on when the heating or cooling kicks on. But if one of those are already going and I turn "fan on" from the stat, the HVAC kicks into overdrive.
    Any logical explanation for this?
    Anyone know a good link where I can learn a little more in depth about the electrical workings of a typical residential HVAC system, i.e, Y, W, C, R, G? I understand their purpose, kind of, but I'm interested in the logistics. No reason in particular - just perpetually curious. Please don't tell me to go to a book store.
    Thanks, Chris
    Apr 2008
    Pa.
    sounds normal to me. I assume you have fossil fuel heat? If you do hvac work you should know your low voltage. Sounds like a DIY er question. So i would call a pro if there is a problem.
    Lots of forums like this that give DIY advice. But not here.
    So you won't have to go to the library.
    Jul 2005
    Quote Originally Posted by Chris75 View Post
    Thanks, Chris
    I don't see this as being a particularly DIYer question, so the short answer is that on fossil fuel systems, and on some electric air handlers, the furnace/air handler itself takes care of bringing the fan on in heat mode. This is information that is found in the instructions of virtually any Wal-mart or HD t-stat that a HO might purchase, so it isn't really a huge trade secret.
    As for a detailed explanation of the low voltage system you might want to do a simple Google search. DIY info or not, there's no point in anyone typing out 10,000 words on a subject that has already been written about thousands of times. HTH.
    Thanks, Chris
    Go to Amazon.
    Oregon
    Thanks, Chris
    Honeywell.com has some good documentation on thermostat operation.
