Results 1 to 9 of 9
    NATE certification
    I was just wondering at how big of a benefit it would be for me to get my natie certification. I am curently laid off and there is basicly no jobs available in my area. Im an installer who went to college for HVAC/R with 2 years of experience.
    does any of you know of some good books to read in studieing for the NATE? Right now i think i would take core installation along with gas heat. Unless your allowed to take more then 1 specialty at a time.
    Thank you
    Sep 2009
    Stumptown,USA
    If you belong to RSES I would say take the Certificate Member exam. The first one is free if you are a member. If you are not a member it is 103.00 to join. If you keep your membership active the certification stays active. with Nate you have to re test every few years. The Certificate Member Certification is equivalent to a two year degree. If you really would rather go with Nate the study guide is $59.00. It comes in a big yellow binder. With Rses the study guides are all online (SAM Manual) for free (if you are a member.
    Muskegon, Mi.
    I know if I was laid off money would be more of a concern than a Nate certification. Just my opinion.
    Central VA
    With the job market the way that it is, i'd go for any advantage i possiblly could.
    Quote Originally Posted by Paul Bee View Post
    good point, NATE seems money driven to me
    Dec 2008
    In the country in NE Kansas
    The last guy that worked for me was NATE certified and since I now know that he was a royal a$$hat and didn't know how to fix much I won't be any more likely to hire a NATE cert tech than a non-NATE cert tech. Just my .02.
    Chicago
    i wouldnt waste my time/money on study guides. i thnk its hard to study for, u either know it or u dont, its lik the ACT/SAT u took in HS, if u know ur stuff ull be fine
    Chicago
    alot of companys get a boner if u have ur NATE, ull prolly be offered more money too
    Jun 2008
    Monroe Ga
    Post
    NATE is just a pretty little card in the wallet along with some abrasive arm patches that scratch the hell out of you. I'm not goin to lie though. I am NATE certified and business owners get horny when they see you have it. For the amount you spend on the test compared to the amount given just for having it is well worth it. the test is hard but the the yellow training manual is very helpful. NATE is the most recognized cert in the business right now so you can pretty much take it anywhere. The business owners like it because they can use it as a marketing tool. NATE has a consumer locator that they can subscribe to. When you weigh the good vs. bad with the test. it turns out economically you will be better off to have it. You can never show enough paper to a potential employer and the more you have the more you are worth. just may be enough to edge out the guy applying for the same position as you.
