    Under The Milky Way
    30HXA Oil Change
    Is there (I can't remember) an oil drain point on the oil separator for a Carrier 30HXA. On the 30HXC and 30GX I can visualize but can't remember if there's on on the HXA or not ????
    A problem shared is a problem halved
    May 2008
    Central Pennsylvania
    I want to say no for a 30HXA, I remember taking oil samples from the oil port on the compressor. The 30HXA doesn't really have much of an oil seperator externally from the condenser barrel. I should be able to let you know for sure later on this week, I'll be at a site that has a few.
    Under The Milky Way
    I'm almost certain but not quite. The 30GX has one on the separator, but the HXA I just can't remember. I think it might be a bleed on the compressor?
    It's a remote air cooled condenser
