Results 1 to 13 of 13
    Aug 2000
    Phila, PA
    oil burner problem delayed ignition
    It takes about 10 sec to lite, this causes a blow back through damper. Checked electrode gaps and nozzle is clean. I'm thinking transformer weak, how do I properly check this, any help appreciated.
    Apr 2006
    s.c.
    there are two testers i use, my favorite is the donagon tester and the powermate, of course the ol screwdriver test, i like a bright blueish white arc
    Oct 2007
    Unhook your burner motor from you primary control so that your pump doesent run fold your ing transformer back. I use my screwdriver touch it directly to one side of the transformer start the furnace and hold over the other side until it arc but do not touch the other side then pull away see how far you can go before it quits arcing if less then half inch i would replace. But i dont think thats your prtoblem . What are you working on ?
    if you are talking commercial burner and you have 10 seconds of oil dumping in there
    YOU
    ARE
    GOING TO
    BLOW
    SOMETHING
    SKY HIGH
    Aug 2000
    Phila, PA
    Quote Originally Posted by dandyme View Post
    YOU
    ARE
    GOING TO
    BLOW
    SOMETHING
    SKY HIGH
    I'm not the most experienced oil guy, but I do know that much!!!
    Aug 2000
    Phila, PA
    Quote Originally Posted by Little NATE View Post
    It's a peerless boiler 300,000 btu boiler with a beckett burner M# CF375.
    What else could it be? I had it apart, cleaned it from side and top, pulled the burner out and cleaned the chamber. Checked gap on electrodes and cleaned nozzle, fired it up and I'm getting delayed ignition?
    Apr 2006
    s.c.
    sorry, actually its the allanson and donagon testers
    Oct 2009
    chicago
    Improper fuel mixture.
    Do yourself a huge favor and get an oil guy out to help you.
    1- is this a single nozzle,duplex or tri-plex?
    2- what is your pump pressure?
    3--is there a solenoid?
    Mar 2006
    Boston MA.
    Quote Originally Posted by furnacefighter View Post
    Ditto !
    Mid Michigan
    What is your air flow like going into the burner and out of the vent pipe.
    You may have a fouled sections. Having done alot of residential
    fuel oil service. I have found that the heat exchanger need to be cleaned
    every couple of years.
    Waddya mean don't thaw out the frig with a knive?
    Jul 2009
    Connectitaxed
    Quote Originally Posted by fr420 View Post
    Is it attempting to light for the 10 seconds ? How is the arc at visual? Pull the the burner at this time and check without fuel to check the ignition. most oil will light up but burn poorly with mixture issues. In other words you should be seeing some burn for a poor mixture unless you have no air coming into the chamber.
    Apr 2008
    most likely primary air set to high on burner blowing fuel away from ignition until it builds up then BOOM!
