Results 1 to 13 of 15
    May 2008
    Central Pennsylvania
    Tech View software download
    Does anyone know if Trane has taken the Tech View download off of there website? Had to get my work laptop overhauled and didn't bother saving tech view, now I can't find it any where on there website.
    Jun 2009
    Florida
    Low Pressure Forever!
    If you know heavy metal, you can work anywhere-Dave Andreson
    Anchors Aweigh my boys, Anchors Aweigh!
    Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
    May 2008
    Thanks CW, I didn't look under design analysis.
    Under The Milky Way
    I can't even get mine to work any more. It won't communicate. I had to change the comms port last time but can't remember how to do it any more.
    A problem shared is a problem halved
    Jun 2009
    Florida
    Quote Originally Posted by bunglebear View Post
    What version are you running? It is up to version 12.1 now. Go to the website and download it to a new folder that you have renamed "CH530".
    Then uninstall the version you have from "add/remove programs" and then run the installation on the new version.
    windy city
    Downloaded the current version and it don't work, must of clicked something in error. Could i reload it after i delete it?
    Under The Milky Way
    Quote Originally Posted by ChillerWisperer View Post
    I'm probably still on v11. I will have to download the latest version and go from there. Last time I used it I had to change COM ports and other things to make it work.
    My biggest issue at the moment is an oil change on a Carrier 30HXA as I can't find a drain point on the separator, so the Techview issue can wait until I try and figure out a way to do the oil change.
    windy city
    what i meant was if i delete my tech view files, will the trane site allow me to re load it?
    May 2008
    HMD,
    I would say yes, that shouldn't be a problem. I'm guessin you'd kinda be starting from scratch then, which is pretty much what I did and it seemed to load up ok, although I haven't hooked up to a machine yet. I reckon things are getting a little chilly in the windy city about now, might be a bad winter. I'm already thinkin about hitting Klove up for some real estate info down in Bama, getting too cold here in Pa for me already!
    Jun 2009
    Florida
    Quote Originally Posted by heavymetaldad View Post
    I'm not sure if I'm using the proper terminology here, but you only need to delete the active version of TV from your computer (the one that currently opens when you click on the TV icon). You can have several versions saved in a folder, but you can't run any two at the same time. One of the early problems a lot of techs had was that they would update to a newer version right on top of the old one without deleting it.
    Create a new folder and call it "CH530", then download TV from the website, saving it into that folder. Then you can install it and even if you delete it later, it still resides as a zip file or something similar in your CH530 folder and you can reinstall it. That's the way Trane teaches you to do it. Back in the early days, it was common for TV to freeze up so bad that the only way you could get back into the MP was to delete and reinstall the same version.
    As far as the TV program, it's still open source and the same one the Trane guys use, with the exception that they have the Kestral software key that lets them do some pretty nifty stuff with it. Not sure where it's going now that IR has taken over. When chillerguy said he couldn't find it, I was worried that it had been pulled from the site. Time will tell.
    has trane made it to where vista can be used with techview yet?
    r404a
    Jun 2009
    Lawng Eyeland
    No Vista support yet. Better that way anyhows.
    Hi there
    Im trying to download the TV 13.0 from here:
    http://www.trane.com/COMMERCIAL/Desi...ew.aspx?i=1435
    But from the link of the TV 13.0 i got the TV 13.0 SP2
    Anyone know were i can find the right download link???
    thanks
