Results 92 to 103 of 103
01-28-2013, 02:07 PM #92
I gotta say I'm impressed with your patience and restraint JP.
From reading this thread from start to finish I was sure that someone was pulling your chain but when I got to the point where they both stated that they were drinking I almost fell off my chair I was laughing so hard.
01-28-2013, 07:58 PM #93
- Jan 2010
- 4,410
Plus this thread is almost four years old.
01-28-2013, 09:38 PM #94
01-28-2013, 11:05 PM #95
New Guest
- Jan 2013
- 4
I have a Bailey walk-in freezer.... How would I calculate the amount of refrigerant needed for this system?
01-28-2013, 11:38 PM #96
New Guest
- Jan 2013
- 4
the link http://sporlan.jandrewschoen.com has expired....
01-29-2013, 02:05 AM #97
You could measure all the tubing in the system piping and both coils and calculate the internal volume. Then work out where there would be various vapor volumes at the various pressures. And so forth.
Or you could look up the total receiver volume for the system refrigerant and then use 75% of that as the charge. If you have to bid the job - use 100%. <g>
I have worked on systems which could not be pumped down - but not very many.
PHM
PHM
01-29-2013, 02:07 AM #98
01-29-2013, 05:37 AM #99
http://sporlanonline.com/90-30-1_072012.pdf
Try that one.
01-30-2013, 12:42 PM #100
- Jan 2010
- 4,410
04-25-2013, 04:32 AM #101
- Oct 2007
- 18
Oh yeah.
This is what I do. Seemed like common sense at the time. First charge as much liquid as you can through the liquid side, and then throttle it in with the gauges at 5-10 psi over the system suction pressure to top it off.
Always worked like a charm.
Oh, and BTW - I never use a digital gauge. Just seems to make me lose touch with whats goin' on. I dont even use a digital vacuum gauge - but instead I collect (yes, I have 4) of the Thermal Engineering vacuum gauges. They are ridiculously cheap if you can find them.
Maybe I am just too much of an ole codger
BTW - looks like ALL of those Sporland links are ded.
04-25-2013, 04:34 AM #102
- Oct 2007
- 18
04-25-2013, 05:45 AM #103
Yeah, I've realized that.
http://sporlanonline.com/literature-...lating-valves/
Look there for more Sporlan info
