Page 4 of 9 FirstFirst 123456789 LastLast
Results 40 to 52 of 116
  1. #40
    Quote Originally Posted by tipsrfine View Post
    Take a chill pill jpsmith, me and thethomas4 had a few drinks last night and it was pretty unprofessional. I know you have good experience and I respect and learn from your post. It's just the way thomas4 said "turn the bottle over and let it suck refrigerant" sounded funny so I poked some fun at him since we were both hanging out with our "buddy weiser".
    On a more serious side, I have seen a very experienced refrigeration man "turn the bottle over" into the suction side and in a flash 10 lbs liquid straight to compressor. We were out in a week or 2 replacing the reed valves. He's getting old and I think he just screwed up due to his age.
    And yes I am speaking from experience-albeit limited-and I understand the gap between theory and what real experience has to say about it.
    Nothing personal, I just get torqued when people start spouting book smarts over street smarts.
    I've seen one compressor damaged in this fashion and it was an air cooled Copeland. My manifold valve leaked past and I didn't shut the cylinder valve off. It flooded out.
  2. #41
    florida
    I always charge liquid into the suction line and have yet to kill a compressor although I have tried to in a pi$$ed off mood.
    Educational forums are open.
  3. #42
    Quote Originally Posted by crackertech View Post
    3/8" hose to the suction service valve.
    You just weren't trying hard enough...
  4. #43
    florida
    Gee thanks I'll try to remember that.LOL
  5. #44
    Monmouth Junction-NJ-USA
    LMAO That is a GREAT TECH TIP!!!!!!!!!!
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
  6. #45
    Quote Originally Posted by rayr View Post
    Always trying to be helpful.
    If you frontseat the valve, the refrigerant will charge faster due to a greater differential in pressure.
    For all the newbies out there, I should post a disclaimer.
    Do not try this at home or on the job. I am a professionally trained idiot.
  7. #46
    When you have the gas out -
    Install a schrader access tee under the TXV equalizing line flare nut. Then blow liquid in there with the system running. The evap will boil it off and the low SSH will throttle the TXV.
    You can also pump 90-95% of the charge into the high side with your recycle machine before starting the compressor. Then just top off to 10 degrees subcooling and you're done.
    PHM
    Quote Originally Posted by AtoZhvac View Post
    Hi,
    I worked with a tech recently who when charging walk in coolers and freezers after compressor change outs. He would cut off the condenser fans for brief periods of time. Both R-22 and 404-A.
    Im just curious at what this was accomplishing and do any of you guys also do this and why? And how is this done properly etc...
    Another thing say you are charging an R22 refrigeration system (large pan cooler) which requires 34 pounds of R-22. I had a heck of a time getting that much charged in. I ran warm water over the container many times to get the pressure back up to charge in the vapor.
    Any tricks out there at speeding this process up? I know that charging liquid is considered a no no and the little liquid charge restrictor device is pretty slow as well.
    PHM
  8. #47
    Southeastern Pa
    PHM
    I always enjoy hearing ideas. Thanks, PHM!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  9. #48
    LOL I had to quote this one...but it was a good laugh
  10. #49
    Come over and hang out for two weeks
    I promise that you Will hear some ideas! <g>
    PHM
    Quote Originally Posted by timebuilder View Post
    PHM
  11. #50
    Dec 2006
    Middle Tennessee
    x1000
  12. #51
    Iowa
    I dont do a lot of refrigeration but on a smaller walk in I will calculate how much liquid the cond coil will hold and then the receiver. I add 80% of what the receiver will hold and what the cond coil will hold. I have done this 3 times and havent had a problem with being short in the winter or overcharged in the summer.
    Bring back rotary phones so we dont have to press 1 to proceed in ENGLISH!!!!
  13. #52
    Oct 2007
    ATLANTA
    Quote Originally Posted by hvacr man View Post
    Hi
    Please tell me how you calculate how much refrigerant to put into the condenser and the receiver.
    Something that really bothers me about the Sporlan Head Master charging data is nothing is considered for the evaporator or the line set. Am I wrong that that does not matter when making a proper charge?
    ps please some of you guys lay off of turning this thread into a joke fest!
    I am sincerley trying to learn something important here and I honestly can not tell when some of you are contributing something useful or joking about something.
