Thread: HI FRIENDS ,CAN SOMEONE HELP
10-10-2009, 06:07 PM #1
New Guest
- Oct 2009
- 3
HI i AM TRYING TO FIGURE OUT IF THIS TERMINATION KIT GOES TO AFIREPLACE HAS ANYONE SEEN PIPE LIKE THIS BEFORE,THANK YOU
10-10-2009, 06:41 PM #2
- Aug 2009
- Arizona
- 30
Looks like sidewall termination cap and pipe for a gas direct vent fireplace.
10-12-2009, 12:49 AM #3
- Apr 2002
- 1,383
Yes --- but it isn't prudent to use whatever kind of venting material that comes to hand when installing a direct vent fireplace.
Rather commonly, direct vent fireplaces need to use the specific vent that they are designed to use or they wont work properly and can be a hazard.
Quite often there is little tolerance on such systems. Install them correctly and they will probably work fine. Miss on some detail and they may work poorly or even be a hazard.
