Results 14 to 23 of 23
    Sep 2006
    Here is something interesting that I found in the search for the EHAH paper.
    It lays out the PR campaign done for the CleanEffects by Trane and their PR consultant.
    http://www.instituteforpr.org/files/...ig_Apple_Award.
    This makes me wonder how many of the participants in the CleanEffects marathon thread we had several years ago were company or PR consultant shills. Naw, noboby would do that.
    Dec 2008
    Upper Peninsula,Michigan
    Quote Originally Posted by breathe easy View Post
    Thanks for sharing....
    Nov 2008
    Spring Green, WI
    Quote Originally Posted by bullmoose View Post
    I prefer a media filter and a UV light. I can't stand the CleanEffects. Piece of crap and a pain in the a$$ to clean... Worst ever!
    i totally agree. a healthy climate merv 16 filter and a sanuvox air purifier do a killer job at removing allergens, vocs, and germs. furthermore, you just throw the filter away after about a year and the sanuvox lamp lasts three before you have to replace it. no more digging through the van to find a chunk of styrofoam to clean the stupid needles on the clean effects.
    something else nobody mentioned in regards to the original thread is that eac's produce ozone. ozone is a lung irritant. can somebody tell me what's the point of putting something in your house to make the air better for your lungs that produces air free from dust but with chemical irritants in it? sounds counter-productive to me.
    Warren, MI
    Quote Originally Posted by jmcgreevey View Post
    I have a Honeywell F50A EAC which was installed in 1981 but replaced the power supply 5 or 6 years ago. The new power supply has a high/low jumper for ozone. After reading about all the ozone stuff, I doubled checked the jumper and it was set to low. I still got a ozone sensor which shows no increase in ozone while the EAC is operating.
    I've mentioned how low my particle counts are here before with little response because most are anti-EAC! The particle counter doesn't care and it doesn't lie.
    Bill
    Nov 2009
    The Trane Clean Effects contributes 5 parts per billion of ozone. The U.S. Food and Drug Administration recommends indoor ozone concentrations should not exceed 50 parts per billion. If your that worried about it, it has a setting to lower it to 3 parts per billion. Ozone should be the least of anyone's worries. There are many other things that put off Ozone inside a house also.
    Dec 2001
    Ocean Pines, MD
    I have a CE in my home. Most, if not all of the CE's we have installed were at the customer's request. We generally use Media types-F-200 or AA 2200 or 5000 line. I had some good response from customers that had CE, as well as the media types but felt that I should try the CE since we sold them. This is less than 5 months so I can't say yet how it does overall, but I did just get over the flu, so....
    We have 5 animals too.
    The CE was installed so it was very accessible but the door is a pain. A common complaint from my customers, my tech's and the installers. I just attended a Trane meeting and it was a common complaint there too.
    Sep 2006
    t825
    5 ppb tested how?
    I hope you are not basing this on the Environmental Health and Engineering study where they mentioned a low number like this where:
    "Ozone levels were monitored continuously (in the test home) over two days on September 21 and 22, 2005 while Trane CleanEffects and air handler fan cycled on and off in accordance with the 70 degrees Fahrenheit set point."
    The tests were conducted in Boston. How often do you think the system was running at that time of year? 10% perhaps.
    So we can calculate a CADR on continuous operation but we can only calculate ozone levels with intermittent operation in a temperate climate in September.
    The fact is the ozone levels from the CleanEffects are irritating to some people. (If you tested them like you would test a standalone air purifier my guess is that they would be somewhere in the 20-40 ppb range.) Just a few minutes on this Board will convince you of that. Trane would be far better served by acknowledging this fact and instructing their dealers in an up front way about this so that they can make sure the customers have the right product at the right setting.
    Ozone is a known trigger for asthma. If an asthmatic has this trigger, the CleanEffects would not be "great for them." It could actually lead to an asthma episode with serious consequences.
    I don't know
    Quote Originally Posted by wptski View Post
    For those who maintain their equipment and use a basic filter upstream of the EAC to remove large particles (pre-filters manufacturers provide don't do a good job), electronic filters are fine.
    In many applications, EACs aren't maintained and the dust passes right through.
    They may be very good for tiny particles, but the primary purpose of a filter is to keep the equipment clean. The best way to keep the air clean is to stop polluting it and ventilate when necessary.
    Dec 2009
    Stamas, can you share with me your understanding of the proper way to clean the corona field charger in the Trane Clean Effects? I'm getting lots of conflicting information.
    Dec 2001
    Ocean Pines, MD
    Sent you an email.
    Same stuff that should have been left with the equipment.
    Pay attention to the date codes.
