Results 14 to 23 of 23
    Oct 2009
    To My 77GMC
    Thanks for taking the time to read and answer technical questions.
    But. Your problem with humidity. Is not caused by your TXV.
    Did you also determine that from GMC's explanation?
    Honestly, I'm not going to take the time to look back through your other requests for information.
    Has the system EVER worked correctly?
    If it has, then YOU NEED A NEW MECHANIC.
    I can't properly diagnose a system without several pieces of information. They are not present in this posting.
    Nobody can give you an accurate diagnosis of a system over the internet.
    Find a neighbor or a friend who knows a GOOD mechanic.
    Or you can keep calling the "best in Phoenix".
    Your money...
    Last edited by jpsmith1cm; 10-04-2009 at 08:18 PM. Reason: Grammatical correction.
    Your money...
    Clue is in one of his other threads.
    I think the "best in Phoenix", are either beer can cold. or, pressures only. LOL
    What's wrong with that?
    That's how I do everything. Even Low temp is 'beer can' cold....
    Feb 2007
    Quote Originally Posted by hoo155 View Post
    Does anyone have any actual technical information besides sitting with a thumb up a nose, critiquing questions? what genius to say ‘get a qualified tech”.
    1) Hmmm. nice way to try to solicit free infomation for what we earn our living by doing.
    No wonder the AC business has so many problems and complaints.
    2) Only when reviewed by sub standard customers.
    These people wasting time saying get a competent technical person, are either usless workers themselves, or not even ac people.
    3) The true meaning to that response is "I really don't want to help you" and you are on my turf.
    First of all techs need to be able to read. It’s been mentioned several times in these postings about the heat pump not dehumidifying, that 2 different “best of phoenix” companies with clean records can’t determine how to fix the heat pump regarding it not dehumidifying. Secondly, these are only a few questions and not all case specific.
    See #1
    If anyone has any real guts, instead taking cheap shots, then give a shot at the following questions if you would like:
    See #1
    oh, to make things clear: 2 different “best of phoenix” companies with clean records came out on a humidity question on a trane xe 1000 heat pump and could not figure out the lack of dehumidification problem and be able to fix the heat pump.
    1. Any idea what would be the point of taking the txv bulb from inside the unit and placing it outside the unit on the suction line?
    2. In this case I was told that the coil on the inside air handler was dry and it was not suppose to be?. That placing the TXV bulb outside the air handler in a new location would fix that problem?. Should that ordinarily fix the problem?
    3. If this bulb is to blame is it letting too much Freon get in? or not enough Freon getting in?
    4. There was mention about moving the bulb to a warmer spot, Does that restrict the amount of freeon? or increases the flow? Why would the suction line be considered a "warmer" spot?
    5. The txv bulb normally sits on the internal part of the suction line does it not?
    Answers to your questions are pretty simple. I suggest you try taking a different approach when asking questions that could save you a lot of money and headaches.
    If it doesn't go easy, you are not using a big enough hammer.
    Nov 2000
    Eastern PA
    WOW!
    The best I can figure out is that the OP is trying to figure out whether or not his txv bulb is wet or not. So, I guess we need wet and dry bulb readings
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Feb 2007
    Cool
    WOW!
    Very nicely put.
    florida
    Oh boy this guy wont quit.
    Educational forums are open.
    Sep 2009
    I frankly was being a smart a$$ because I was afraid to break forum rules.
    For that I apologize for not being more helpful.
    R-HVAC techs make the world a cool place.
