    Sep 2009
    Aireflo condensor question
    After servicing unit I put the capacitor back in unit and it sparked and then the compressor would not come on but the outdoor fan did start. Is there an internal overload protection that may have kicked in?
    I do not have much experience with these units so I thought I'd ask here.
    Nov 2007
    Are you a professional technician? I only ask because you could apply for pro membership and then we could discuss these technical questions...otherwise not much luck in the general discussions on DIY.
    Nov 2007
    As beenthere has also informed you of this:
    Sorry, this is not a DIY site. So we are not allowed to give out advise of this nature.
    Since answering your question in the open Residential Forums would be posting instruction for DIYers that may read this post later.
    If your in the trade, get your post count up to 15, and apply for Pro Membership.
    Then use this link Apply for Pro Membership
    Once accepted, you have access to the pro tech forums. Where you can ask and get answers to technical questions.
    Plus, you also have access to the Pro Educational Forums.
    All of it is free.
    Have you applied??
    Sep 2009
    Yes I have applied and yes I am a professional....wasn't sure where to post.
    I submitted my licensing info and other info requested.
    Thank you!
    Nov 2007
    No problem, look forward to helping any way possible. I have installed a couple of these in the last few weeks and have had no problems..good luck.
