Results 1 to 13 of 13
    West Palm Beach,FL
    what brand of a/c is this unit:
    The brown one on the left.
    Thanks.
    Ed
    West Palm Beach,FL
    also any idea how old it may be?
    Aug 2009
    MT JULIET,TN
    I'm not positive,but that looks like a old goodman unit to me,if not someone will be along shortly to correct me!!!
    Anything worth doing,is worth doing RIGHT the FIRST time around!!!
    Dec 2006
    Pinellas County, Fl
    have you ever had it serviced? if so look on an invoice and see if there is a model# and a serial# so we can help with the age
    Improvise, Adapt and Overcome
    West Palm Beach,FL
    its not mine. its a unit near mine and im the HOA president and the potential buyer was asking me if i knew what kinda/how old the unit was.
    its the only one around here that looks like that..
    Illinois
    I'm going with early 1990's Goodman.
    The cube on the right looks like a early 1890's
    Dec 2006
    Pinellas County, Fl
    if your the president can you access that roof and maybe get some numbers from the looks of your pic the data plate looks intact
    Nov 2005
    sacramento calif.
    two rheems, a goodman and a gaffers & sattler.
    i was born under a wandrin star.
    Arizona
    Quote Originally Posted by ewalker3 View Post
    Thanks.
    Ed
    It is a Goodman package heatpump or package A/C. Model PHK**** whatever.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Jun 2007
    Round Rock
    It looks like the old Janitrol unit to me. It's the stupid door over the door on the right side that gives it away. Pain in the arse. Burn the crap out of your fingers when you take the hose off the high side unless you have the low loss gauges.
    I like DIY'ers. They pay better to fix.
    Feb 2007
    Las Vegas,NV
    It's actually a fairly new unit. It looks to be one of the last models before they changed the color and shortly after added coil guards.
    They way you can tell that it's newer, is that the coil end of the unit does not have rounded corners, as the older units did.
    Arizona
    Quote Originally Posted by bmathews View Post
    Goodman/Janitrol, same thing.
    Arizona
    Quote Originally Posted by sammy37 View Post
    Ditto
