Results 1 to 13 of 17
Thread: reuse
    Aug 2009
    tn.
    reuse
    I just installed a condensing unit r-410. Everything was fine running good and got through inspection. Than i had to uninstall the system. Afraid the this unit will be stolen. I recovered the ref and cut it out. Can i put the ref back into the system? Brand new recovery tank that i had just pulled a vacume on . Also can I reuse the LL dryer and suction dryer I know that they have exposed to air and I just want to do the right thing? Thank Frank
    Dec 2006
    Pinellas County, Fl
    The driers are garbage as soon as you used them and cut them out, as for the r410 it has to be recycled cause its no longer virgin, you cant put it into anyones equipment
    Improvise, Adapt and Overcome
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by frank26601 View Post
    doing things right would have meant pumping the system down
    anytime you open a 410a system, it gets a new drier
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by jdrob12000 View Post
    incorrect!
    Aug 2009
    tn.
    So I should not put the refrigent back in the same unit?
    Dec 2006
    Middle Tennessee
    how did you do all the work, but yet you don't know the answer to this
    Aug 2009
    tn.
    I am just not sure that is why I asked.
    Sep 2009
    Story City, Iowa
    Don't know how you do the work if you don't know the answers to your questions.
    As for the suction drier on 410A...good luck with that.
    "The difficult we enjoy, the impossible just costs more."- My dad
    Quote Originally Posted by MechComf View Post
    That is the reason for this site.
    For techs to learn what they don't know.
    Questions like this. Are not uncommon. Mostly because many companies were reluctent to start installing them. And didn't send their techs to training courses.
    He probably knows the answers for an R22 system.
    Dec 2006
    Pinellas County, Fl
    What was incorrect when i got my epa cert the rule was recovered refridgerant could not be reused
    Ain't no such EPA rule, law, or regulation.
    EPA regs do NOT allow it to be sold to another customer.
    But it may be reused in any equipment that, that owner/customer owns.
    Dec 2006
    Pinellas County, Fl
    i stand corrected. I did not catch that he was reusing in the same equipment.
    Sep 2009
    Story City, Iowa
    Frank, you can reuse the refrigerant in this unit. Sounds like you took proper precausions with tank.
    Absolutely do not use the driers again.
    Read on R-410A Always good to educate yourself as much as possible.
    A suction drier should NOT be used with R-410A.
    Even in the case of a severe burnout they caution to only leave a suction drier in system for I believe 12 hours of operation. Then it is to be removed, new liquid drier installed and complete purge and evacuation of system down to 500 microns. The polyolesther oil is like a sponge and absorbs moisture almost instantly.
