Results 1 to 13 of 13
10-01-2009, 08:45 AM #1
- May 2009
- 26
Condensing unit - clunking noise when shuts off
Hi, I just noticed that my outdoor unit is making a louder than what I believe is normal clunking noise when it shuts off.
Is this cause for concern? The (Carrier) unit it slightly over 1 year old and otherwise, works fine . . .
Thanks!
10-01-2009, 10:10 AM #2
- Dec 2006
- Pinellas County, Fl
- 78
I would call a pro on this one, there may be problems with the compressor that if caught in time could save it
Improvise, Adapt and Overcome
10-02-2009, 06:45 PM #3
- May 2009
- 26
The tech came out and said everything was fine. Explained that is was the pressure equalizing instantly (something like that).
10-02-2009, 07:50 PM #4
Professional Member*
- Jul 2006
- Virginia
- 3,719
did he make sure the fan blade set screw was tight
10-02-2009, 09:32 PM #5
- Dec 2007
- Cedar Grove, Wi-Sheboygan
- 1,582
sure it wasn't the duct work you were hearing making the noise from expanding and contracting form the heat and cool air? When the heat kicks in the duct works expands, and shortly after the heat turns off the duct work will contract.
10-02-2009, 10:25 PM #6
- May 2009
- 26
10-02-2009, 10:26 PM #7
- May 2009
- 26
10-04-2009, 01:53 AM #8
- Dec 2007
- 1,582
Has to be the line sets coming into the house then, check the lines when the OD unit is running and also check the line inside
10-04-2009, 08:09 AM #9
Is this a heat pump?
Remember, Air Conditioning begins with AIR.
10-04-2009, 09:54 AM #10
- May 2009
- 26
10-04-2009, 09:57 AM #11
- May 2009
- 26
10-04-2009, 11:01 AM #12
- Aug 2008
- 322
What kind of compressor does it have? If it has a scroll it could be turning backwards untill pressure equalises.
10-04-2009, 11:17 AM #13
- May 2009
- 26
