Results 1 to 10 of 10
    Sep 2009
    media filter and effect on heating/cooling bills?
    sorry, this is a newbie ? but what effect would placing a media filter be on bills? Does it decrease efficiency by having to push through the thicker filter? Are media filters worth it (currently just have the standard filter).
    I don't know
    All filters restrict airflow.
    For a given level of filtration, media filters are far less restrictive than their 1" counterparts due to higher surface area.
    The objective of using a filter is to keep the equipment clean; the lowest level of filtration which can keep dust from accumulating on blowers and coils should always be used. (Fiberglass MERV 1-2 for conventional/mid efficiency furnaces with no a/c, maybe Merv 5-8 for high efficiency furnaces and a/c or heatpump systems)
    On air handlers/furnaces with standard multi-speed/belt drive blowers, filters reduce air flow resulting in less efficient heating or cooling. (lower airflow = less work = lower motor amp draw but higher overall energy consumption)
    On air handler/furnaces with variable speed ecm blowers, the fan speed increases in the presence of a restrictive filter to maintain airflow as the media gets dirty. (Noise and energy consumption increase, motor lifespan declines)
    Have a contractor check the external static pressure of your duct system to determine which type of filter is appropriate.
    Nov 2008
    Chapel Hill, NC
    Quote Originally Posted by amd View Post
    The objective of using a filter is to keep the equipment clean.
    Well, that's one objective.
    Aug 2009
    Kansas City
    Quote Originally Posted by DJCooleo View Post
    There are several things to factor as this is not a yes or no answer. First of all is the airflow ok with the standard filter you have in place. And by ok I mean is the system moving the amount of air it is designed for. The biggest benefit, from what you are asking, that you will receive is the media filter allows you to trap more dirt without reducing as much airflow. So as the filter loads up with dirt you will stay closer to designed airflow requirements which will keep efficiency closer to what is spec'd. Also you will not strain the equipment as much which will in turn increase the life span.
    I don't know
    Quote Originally Posted by sktn77a View Post
    I haven't seen a single study which demonstrates that furnace filters can improve IAQ.
    Bypass HEPA filters aside, residential equipment was never designed to clean the air. Good IAQ is best maintained with proper ventilation and source control.
    Aug 2009
    Kansas City
    I do not to see any study from someone else on this. I have learned from first hand experience. Pretty much all of the new homebuilders expect to run their furnace in the winter in the KC area to heat the home during construction. This plays havoc on a new heating and cooling system. Sometime between 2002-2004 Carrier/Bryant started supplying furnaces with a 4" media filter cabinet in them. The company I was working for at the time decided to use this to their advantage and installed them on every new home and change out. After doing so we did not replace a single blower motor due to failure because of the damage sheet rock dust can do to a system. It does not take a study by a third party to confirm this is a good thing.
    May 2009
    Condensing unit - clunking noise when shuts off
    (removed)
    Admin, please delete
    I don't know
    Quote Originally Posted by yourairman View Post
    Yup, that would fall under protecting equipment.
    Not sure if media filters actually improve iaq.
    Ideally builders shouldn't be allowed to run hvac equipment during construction.
    Aug 2009
    Kansas City
    This post is about efficiency with media filters not IAQ. If you keep dirt and debris out of the furnace blower and indoor coil wouldn't you also be keeping it out of the air supply? The answer is yes. And to answer the original post you will not achieve higher efficiency with clean versus clean. As the filters load with dirt the media filter will not lose as much air flow which in return maintains efficiency of the equipment.
    Nov 2008
    Chapel Hill, NC
    Unfortunately, "Indoor Air Quality" is hard to define. If it's hard to define, it's hard to measure. If its hard to measure, then its hard to improve. That's probably why the studies are unable to come to any useful conclusions one way or another.
