Results 1 to 10 of 10
Thread: Carrier wiring diagram
09-29-2009, 07:22 PM #1
New Guest
- Sep 2009
- 3
I have a carrier Air Handler model # FA4BNFO36000AAA , and a serial number of 1905A69448, Im in need of the wiring diagrams for the wireing from thermastate and outside heat pump, I think I was told its called field wiring diagram but not 100% sure. I'm useing a outside heatpum, Nordine 3 ton unint with a 3 ton slant coil. Anny info is greatly appreciated
Shawn
09-29-2009, 07:25 PM #2
So...are you a technician?
09-29-2009, 07:31 PM #3
New Guest
- Sep 2009
- 3
not a Heating and Aur Tech, Im a Aut Tech, this is going in my shop, and the Heating Tech thats heling install this askd me to try and locate this info
Shawn
09-29-2009, 07:36 PM #4[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
09-29-2009, 07:39 PM #5
New Guest
- Sep 2009
- 3
09-29-2009, 07:53 PM #6
Tell your tech, that the local Carrier distributor can help him.
09-29-2009, 08:17 PM #7
- Nov 2004
- 1,007
09-30-2009, 03:03 PM #8
But of course..A tech should know that..
But he must be a specialist...because electric air handler/heat pump thermostat wirings can be real tough..
09-30-2009, 05:56 PM #9
OK. You're an auto tech. So, this unit is for your auto repair shop.
First, if I were you* I would install a heater that runs on drain oil. A lot of people are intimidated into using Saf T Clean to take their oil away, but in most jurisdictions, you can still use drain oil to heat an auto repair shop.
Second, you should have your AC tech get this info, as it is not available outside of the profession. You'd have more luck getting Toyota to give you the software in their ECM for fuel trim.
*I once explored the idea of having my own shop[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
09-30-2009, 07:15 PM #10
Why are you putting a Nordyne heat pump on a Carrier air handler???
nagakatta yo mou sukoshi de atatakai hizashi abireru, honto wa gutto koraete'ta jibun ni dake wa makenai you ni, nagakatta yo mou sukoshi de atatakai hizashi abireru, hanarete sugoshiita jikan ga samishiku nakatta to ittara uso ni naru...
Not as lean, not as mean, but I'm still a hardcore, ass-kicking, hard charging Marine! Oohrah!
