Results 1 to 10 of 10
    Sep 2009
    Carrier wiring diagram
    I have a carrier Air Handler model # FA4BNFO36000AAA , and a serial number of 1905A69448, Im in need of the wiring diagrams for the wireing from thermastate and outside heat pump, I think I was told its called field wiring diagram but not 100% sure. I'm useing a outside heatpum, Nordine 3 ton unint with a 3 ton slant coil. Anny info is greatly appreciated
    Shawn
    Illinois
    So...are you a technician?
    Sep 2009
    not a Heating and Aur Tech, Im a Aut Tech, this is going in my shop, and the Heating Tech thats heling install this askd me to try and locate this info
    Shawn
    Southeastern Pa
    Quote Originally Posted by IndianaShawn View Post
    Shawn
    OK, I'll ask.
    What are "Aur" and "Aut?"
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Sep 2009
    OK, I'll ask.
    Misstype, I cant type for nothing tonight, LOL Im not a Heating & Air Tech, Im a Auto Tech.
    Tell your tech, that the local Carrier distributor can help him.
    yep
    Sep 2009
    But of course..A tech should know that..
    But he must be a specialist...because electric air handler/heat pump thermostat wirings can be real tough..
    Southeastern Pa
    OK. You're an auto tech. So, this unit is for your auto repair shop.
    First, if I were you* I would install a heater that runs on drain oil. A lot of people are intimidated into using Saf T Clean to take their oil away, but in most jurisdictions, you can still use drain oil to heat an auto repair shop.
    Second, you should have your AC tech get this info, as it is not available outside of the profession. You'd have more luck getting Toyota to give you the software in their ECM for fuel trim.
    *I once explored the idea of having my own shop
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Apr 2008
    Pluto
    Why are you putting a Nordyne heat pump on a Carrier air handler???
    Not as lean, not as mean, but I'm still a hardcore, ass-kicking, hard charging Marine! Oohrah!
