Results 1 to 12 of 12
    Thoughts on Mr Slim + Competitors
    Greetings all,
    I am a student at Georgia Institute of Technology doing a class project concerning the Mr Slim line of AC products.
    If anyone is willing to help me I would greatly appreciate people posting their experiences in this thread.
    The kinds of information I am looking for is:
    Have you used Mr Slim and been happy/unhappy with it? Why or why not?
    What kinds of installations have you used it for?
    Have you considered using Mr Slim? Why did you choose not to use it?
    What alternative products did you consider/use instead?
    Thanks in advance for your responses,
    Jon
    Colorado flatland native
    Great Q Jon....
    My only reasoning for going with Mr Slim and never even checking the other guys out is I wanted the japanese innovator. That meant either Mitsu or Sony. Kinda like comparing a Toyota to a Kia [the korean imitator]. The Japanese company will always outperform them. I stay with mitsu because they just keep getting better..... and the prices havent gone up much for the better product.
    Walter Matthau
    Jun 2002
    Bemidji, Mn
    Troubleshooting these things is a PAIN IN THE BUTT. They are great units but as far as diagnostics, they stink. I have to call the techline one day here to verify that the one in my place has a bad board. No way to tell that I know of.
    (ices up after the electronic exp valve). Pulse signals to the valve are impossible to check, arent they?)
    You picked a fine time to leave me loose wheel...
    http://rapalaguy.spaces.live.com/
    Jun 2002
    Bemidji, Mn
    Hey Spotts, since your a dealer in these I may have to ask a favor as NONE of my distrib's carry parts for these. I dont feel like opening more accts.
    Jun 2002
    Bemidji, Mn
    I have had mine for 5 years, and I run the heat pump in very cold temps, even at 10 degrees outside I get a 30 degree rise. It has been a very good unit (until now), the unit draws around 5 amps from the compressor, unreal. (I have the inverter series).
    Thanks for your replies fellas,
    Chad/Spotts - would you get one again? What kind of room did you use it for - an add-on?
    Bay Area, CA
    Quote Originally Posted by masonreloaded View Post
    1) Yes, Happy with it. Easy to troubleshoot, most parts are easy to replace. Though if you get stuck with one of those hidden parts you'll hate the rest of your day. The other downsize is one thats general across the board they use to much plastic and clips and if your not patient i've cracked a few covers.
    2) Resi, small comercial, server room
    3) Last I checked they are a bit more expensive then fujitsu and resi customers might be more inclined to go with them
    4) Daikin
    Global Warming or: None like it hot
    No pleasure, no rapture, no exquisite sin greater... than central air. -Dogma
    Jun 2002
    Bemidji, Mn
    Green jumper, can you explain to me how to diagnose why the electronic exp valve isnt working. Im pretty sure its the board but ... I ohmed out the exp valve (has 6 wires). like I was told via mr slim. They all had 55 ohms which is what they said it should. I just dont feel like going though the bs of getting a tech online right now.
    Lancaster PA
    Quote Originally Posted by Chad711 View Post
    Ask that in the Pro tech forums.
    Bay Area, CA
    Its ok bt you can say it here, you diagnose eevs very carefuly
    Jun 2002
    Bemidji, Mn
    I sent you a PM Green Jumper.
    Lancaster PA
    Quote Originally Posted by green jumper View Post
    ROF
