    Sep 2009
    duroguard what size is it?
    I cant find any info on this 10 seer duroguard model dade-030ja, serial 6933t2105. I need to know btu. Help please. tks, paul
    2.5 ton.
    Hopefully, you'll also have the indoor unit/coil replaced if your replacing it.
    Sep 2009
    How do you know the size and what does that second comment mean?
    The 030 in the mod number. Means 30,000BTU, 2.5 tons.
    If you needed that info because you plan on having a new unit of the same size installed. You should replace the indoor, so you get what you pay for.
    A new 13 SEER condenser on an old coil, doesn't always work well.
    Sep 2009
    why cant I find any info on duroguard on the net?
    Nov 2005
    sacramento calif.
    because its a generic knockoff of a rheem product commonly used in the apt. industry and advertising would add to the units cost.
    i was born under a wandrin star.
