Results 1 to 13 of 14
Thread: McQuay Terminal install
09-28-2009, 09:47 PM #1
McQuay types:
I have to take down a 134a centrifugal to replace the motor terminals on. The new terminals have a torque rating of 20 ft pounds, pipe thread type. I was thinking of using Loctite 554, what do you guys think?
r404a
09-28-2009, 09:49 PM #2
- Jun 2009
- Lawng Eyeland
- 97
how are the terminals connecting? with an o-ring? describe.
09-28-2009, 09:52 PM #3
MK
These are actually just pipe plug threads, no aluminum crush washer or oring.
Loctite 554 is about the best thread seal for refrigerant, I just want to see what you guys think.
r404a
09-28-2009, 10:03 PM #4
- Jun 2009
- Lawng Eyeland
- 97
Yeah I'd say that cherry syrup is a good bet. Regular good ole blue LeakLock works just as well.
09-28-2009, 10:03 PM #5
- Dec 2005
- North America
- 204
Hello
Just did and O87 I used 554 on the threads and 515 on the O ring I know that sounds odd but it works well.
09-28-2009, 10:05 PM #6
thanks guys
looking at my breakdown and the terminals I have, thet are just pipefitted.
r404a
09-28-2009, 10:05 PM #7
- Jun 2009
- Lawng Eyeland
- 97
good ole 515. we got an old timer nicknamed that cuz he used so much when it first came out it got stuck on the IGV's. He still laughs when I call him that.
09-29-2009, 05:57 PM #8
I use 554 with no problems. I never had to remove it either after using it.
10-01-2009, 07:15 PM #9
Member
- Dec 2005
- Rockhill South Carolina
- 370
hope you ate your wheaties before you pulled the originals,567
10-01-2009, 07:37 PM #10
I have had them break off at the motor shell, thats alot of fun to get out then.
10-13-2009, 03:54 PM #11
10-13-2009, 05:10 PM #12
not all of them used o-rings, the ones without needs a sealant
10-13-2009, 08:22 PM #13
Member
- Dec 2005
- 370
thanks freonrick
