Results 1 to 13 of 15
Thread: Which thermostat wire to use?
09-25-2009, 05:19 PM #1
- Jun 2009
- Albuquerque NM
- 2,445
My HVAC guy will be coming over to install a new thermostat (WR 1F95-1291) and do a fall furnace cleaning/startup. We're relocating the t-stat and he asked what kind of wire (how many conductors) I want him to put in. I've been thinking about putting in a heat pump and humidifier and I mentioned this to him. So, it kind of depends on what I eventually put in, but I'd like to have as much flexibility as possible for wiring stuff in.
09-25-2009, 05:39 PM #2
Professional Member*
- May 2008
- Missouri
- 2,623
Put in at least 8 wires, and if he doesn't protest, then have an additional 4 wire pulled at same time. That way you can put in any type HVAC unit with options. But get at least 8 wires!
09-25-2009, 05:45 PM #3
- Jun 2009
- Albuquerque NM
- 2,445
09-25-2009, 06:46 PM #4
- Apr 2007
- Pa,
- 87
Just make sure it is 18 gage. Don't go for that economy 22 gage crap, it will only give you problems.
09-25-2009, 06:58 PM #5
Use a Honeywell IAQ and you only need three.
09-25-2009, 07:17 PM #6
- Jun 2009
- Albuquerque NM
- 2,445
09-25-2009, 07:20 PM #7
Banned
- Oct 2003
- Washington
- 7,405
09-25-2009, 07:35 PM #8
09-25-2009, 07:36 PM #9
09-25-2009, 10:42 PM #10
- Jun 2009
- Albuquerque NM
- 2,445
09-25-2009, 10:44 PM #11
- Jun 2009
- Albuquerque NM
- 2,445
09-26-2009, 05:23 AM #12
It won't add humidity during, or right after a cooling call, that is correct.
So if your trying to add humidity in the summer cooling months, it won't.
It will in the heating season though. And as you said, it has to have had at least one heating call to activate the humidify function.
But after that first heating call. It can humidify any time, weather to not its doing a heating call. Until either the system switch is set to off, or it does a cooling call.
So are you trying to add humidity in the cooling season.
09-26-2009, 08:11 AM #13
Banned
- Dec 2006
- Middle Tennessee
- 11,347
you surely wont need more than 12 wires
but some o.d. stats need there own 2 seperate wires running to the stat
tell your a/c tech what control methods you require
if he's not sure how many wires to run (as you implied), he may not be the right guy for the job
