Results 1 to 9 of 9
    Sep 2009
    Wisconsin
    Heat Exchanger Good?
    How would a homeowner know if their Heat Exchanger has gone bad (a.k.a. Cracked)??
    I have a 26 year old furnace. Still works fine.
    call a professional to check it.
    it needs to be inspected, not really a way for the homeowner to know.
    I don't know
    In most cases, it's impossible to determine the integrity of a heat exchanger without pulling the blower and burners. (DO NOT EVEN ATTEMPT!) It's possible to see approximetely 1/3rd of the heat exchanger on natural draft furnaces without taking anything apart. (aside from removing the cover)
    You should get it checked every year.
    The likelyhood of finding cracks in a 26 year old unit is extremely high - plan on getting it replaced.
    Sep 2009
    Tucson, AZ
    Quote Originally Posted by Tony49837 View Post
    26 years old is WAY up there in age for a furnace. There is a very high probability of a heat exchanger crack or other type of dangerous situation with your furnace. (Gas flex to the furnace may even be unsafe) Contact a professional to do a thorough inspection on the unit.
    buy a canary and put the cage near a supply duct
    if there are any peta members ...........KMA!!!
    Have your heat exchanger inspected.
    At 26 years. Its served you well though. Might be time to check into replacement even if its not cracked or burned through.
    Sep 2009
    Wisconsin
    I have a replacement scheduled to be installed next month. A new Bryant 355CAV with the Evolution Control.
    Sounds like I'm making the right decision even if my old unit still works.
    Northeast Ohio
    You will pick up a minimum 5-6% operating efficiency over your old DMO, have piece of mind and a nice new warranty. Win win win.
    DEM
    Aug 2009
    Kansas City
    A cracked heat exchanger does not keep a furnace from working. It does have the potential for allowing Carbon Monoxide into the living space. 26 years old is a good life for a furnace.
