Results 1 to 12 of 12
Thread: Installation
    May 2009
    Up State S.C.
    Installation
    After Ryan's OK, I bought a Infinity system in June ( HP, Furance, Evaporator and By-Pass Humidifier . I know it does not pay me to think - anyway, the humidifier is installed in the plenum (upflow) it has a flex duck from the return to the humidifier (by passes the filter). Seems to me when the Humid. is on and the fan quits blowing that any dust or dog hair would fall on the coils.
    From your description, it sounds like a perfectly normal installation. But I can't see it from here. Any pics?
    Northeast Ohio
    Air flow is from the plenum side to the return side so there won't be any substantial dust, dirt or hair in the loop irregardless of whether the return collar is cut above or below the filter. It's the air coming back to the furnace from the return system of the house that is dirty.
    May 2009
    Up State S.C.
    I will try some pic's. It draws air from the return (by passes the filter) to the humidifier.
    Lancaster PA
    No.
    Air from the supply is pushed through the pad into the return.
    Jun 2000
    B.C. Canada
    No.
    Exactly, the air that goes from the discharge through the pad is already filtered then going into the return through the filter again. Got that?
    May 2009
    Up State S.C.
Size:  47.0 KBName:  IMG_0807.jpg
Size:  47.0 KBIf ya'll are telling me that the filter in the humidifier will filter the air, OK.
    Northeast Ohio
    The air going through the humidifier pad is already filtered.
    Jun 2000
    B.C. Canada
    Quote Originally Posted by M&B View Post
    Lancaster PA
    Quote Originally Posted by heaterman View Post
    Yep, so it just recirculates filtered air.
    Standard installation for a bypass humidifier.
    burlington county n.j.
    that is not a filter in the humidifier, it is a water panel.
    air flow ges through the humidifier in the opposite direction you think it does.
    humidity is introduced into the return side of the system with a bypass humidifier.
    Cedar Grove, Wi-Sheboygan
    Just remember to change that pad in the humidifier before every heating season, there cheap, just don't throw away the plastic frame that holds the pad like I did once not thinking
