Results 14 to 26 of 40
    Apr 2008
    Northwest Arkansas via Chicago Area via Straight Up from There on Lake Superior
    Most geo systems have it.
    And some standard air to air systems do also.
    That an add-on to air to air HP, BT? Any brand names? Thought most pro's bad mouthed HW from HP, except from geo.
    Its an add on for air to air.
    How much benefit you will get from a newer high efficiency unit today. is questionable.
    But, in hotter climates, and or areas with long cooling seasons. they may get some benefit.
    Sep 2009
    Beenthere, do you have some links to those? Would be interested in doing some reading. Down here, my AC runs so much that I find it terribly ironic that I'm using electricity to heat water.
    Grottoes VA
    Here is a link to a Popular Science article from 1980. Nothing has really changed in the 30 years since that was published.
    http://books.google.com/books?id=cUp...%20tap&f=false
    Except the install price is a LOT more.
    Baltimore MD and Ridgebury PA
    Why is it that the new higher efficient units offer less of a benefit? It would seem that its just a matter of where you are putting the 'waste' heat... outside or into the water... obviously there is more to it than that... why?
    They flowing higher refrigerant volume. So less temp(Not BTU an hour)from the compressor discharge.
    So won't always heat the water to as high of a temp. And once the tank is hot. And no one is home. All the A/C heat is still being rejected outside.
    Grottoes VA
    Yeah well that's true.
    Nov 2001
    Seattle, WA
    I've worked on two of these made by ETech. I think they have been bought out by another company. Definitely makes the room colder but they work great, very little maintenance and tend to last long. The ones I know about are over 10 years old and still working.
    They are noisy though.
    - Alexis de Toqueville, 1835
    Thank you, that does make sense. Basically the delta T between the water you are attempting to heat and the compressor discharge becomes too little right?
    Quote Originally Posted by platchford View Post
    Yes.
    If you use it with/on a preheat tank. Then its not a real problem. Just adds cost to initial install, and adds time to payback.
    Nov 2009
    I want one.
    Nov 2009
    I've been thinking about this HPWH thing lately. To Jerryd, Rheem, Geyser and many others have HPWHs. The claim to fame of GE's hybrid design is that it's the first to get certified under new energy efficiency standards.
    I've been wondering about the cooling problem this technology presents. Does anyone know how much the air temperatures changes from inlet to outlet? A regular family size unit for example.
