Results 1 to 13 of 14
    Jun 2007
    Rochester, NY
    condenser coil cleaning
    I have heard from a local supplier that you should use a torch to burn off any cotton wood and stuff on the condenser coil and then rinse it with a hose. Is this something new I have never heard of this. Also I am in the commercial side of things and would that be something you would recommend for commercial equipment. Thanks in advance for any insite into this.
    You have the post count, apply for Pro Membership.
    Then use this link Apply for Pro Membership
    Once accepted, you have access to the pro tech forums. Where you can ask and get answers to technical questions.
    Plus, you also have access to the Pro Educational Forums.
    All of it is free
    We don't go into things like this in the open forums.
    Jun 2007
    Rochester, NY
    thank you for the advice and I will be sure to apply for the pro form thanks again.
    Nov 2008
    Biloxi, Ms.
    Quote Originally Posted by moyerboy2 View Post
    You are joking, right?
    Quote Originally Posted by ball a/c View Post
    There are certain coils that are cleaned that way.
    They're the exception, not the rule though.
    Yeah, thats true.
    I know a big corp here with some Mammoth RTUS. Some how the condensers are coated in small fibers from trees and plants. Not cotton but similar.
    The Mfg rep service guys flew in from Denver and said they can burn off the stuff and have done it before.
    Hey cockroach, don't bug me! ©
    Nov 2008
    Biloxi, Ms.
    Quote Originally Posted by the dangling wrangler View Post
    I wasn't concerned that they might be doing it in New York or Denver, but Houston, that too close to me. Are you sure that those yankees aren't trying to trick us again.
    I'm not sure of anything, anymore.
    Ya gotta keep in mind , how the flame on the torch is set up.
    It ain't for soldering.
    Personally, I've never done it this way, only heard of people doing it.
    Nov 2008
    Biloxi, Ms.
    45 years ago they told me to check for gas leaks with a match.
    That was exciting with propane.
    Guess it was a small leak.
    Jun 2007
    Rochester, NY
    The supply house said to use a lazy flame on the end of the torch. I was just wondering if maybe this was the alternative for chemicals. Thought maybe the companies were trying to get away from using them.
    Most of the coils that you would clean with a flame, would be the spine fin type. But, not always.
