Results 1 to 8 of 8
    Ottawa, Canada
    Cutting MFD with a jigsaw
    I'm having a hell of a time rounding the corners on a 3/4inch piece of MDF. Trying to make an oval type shape but the blade seems to angle out, not giving a "true" cut. I'm using a wood balde at a high speed. Should I be using a different balde, maybe smaller teeth at a lower speed? thanks for any help.
    Last edited by CDNtech; 09-22-2009 at 09:35 PM. Reason: Dyslexic, Subject should read MDF
    Jul 2009
    Plant City, Florida
    Quote Originally Posted by CDNtech View Post
    I'm having a hell of a time rounding the corners on a 3/4inch piece of MFD. Trying to make an oval type shape but the blade seems to angle out, not giving a "true" cut. I'm using a wood balde at a high speed. Should I be using a different balde, maybe smaller teeth at a lower speed? thanks for any help.
    What is MFD?
    MDF is Medium Density Fiberboard.
    Try a lower speed, or use a router with a pattern bit.
    Quote Originally Posted by bwalley View Post
    What is MFD?
    Router was my first thought, too.
    Maybe one of those roto-zip type saws would work for you.
    Cheap blades will bend try a better brand.
    Ottawa, Canada
    What is MFD?
    Haha, that's what I meant. Thanx for the tips guys, just tried a lower speed with bi-metal blade. Worked like a charm.
    Don't MFDs live in capacitors?
    florida
    Smart a$$
    Educational forums are open.
    Cedar Grove, Wi-Sheboygan
    MDF and any type of blades don't like each other, especially Carbide. What kind of jigsaw are you using, is the foot of the jigsaw square to the blade ? Your best option in the future would be to use a pattern and router to cut your corners if you need to have a nice square finished edge otherwise if this is for some fast fix for something the jigsaw will do.
