Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 64
  1. #40
    Quote Originally Posted by Home&Marine View Post
    Oh my, some opinionated persons huh?
    Well, I don't know how much time some of you have spend on a commercial roofs but in some cases a walk back to the truck can cost 20 minutes. I normally have a Gerber, a pair WR-5 ViceGrips and a small flash lite. All items have saved me daily. Normally I'll go check a unit prior to hauling 40 pounds of tools to it. I do own two homes and a 34' boat so yep I guess I qualify as a HO and DIY? I guess that's true too, 'cause if it's broke I can fix it!
    Diceman I do understand your opinion but at 53 years of age I've learned to work Smarter not harder. If one of my multipurpose pocket tools saves me time and gets me out of a jam, I'm happy.
    I almost forgot. I keep several 4 in 1 screwdrivers around. Where they've saved me before the using the shaft as a nut driver. I think I have one Stainless Steel that came from West Marine.
    Well I'm 4 years older than you and when I go on a roof I take my hand tools, everything I need to at least diagnose a unit is in there.
    A tool pouch that really isn't that heavy.
    I'm just kidding a bit too............
    Hey cockroach, don't bug me! ©
  3. #42
    I can see walking around with a leatherman on your belt....... but on a service call I take my real tools. I been on more commercial roofs than I can remember and it does suck to haul your ass back to the truck................which is why I take my hand tools in the first place.
    I have found multi tools just don't fit the need of normal, single purpose tools.
    Not even close.
  4. #43
    Sep 2009
    I love my klein tools I tell everyone at work if it aint klein it aint mine. But that's bs now..the klein 1000000 in one or whatever the hell it is is great, but Lenox makes a good multidriver too. As someone else said it's always a good idea to have the ONE right tool. But Multitools are convenient for mostly low torque applications..that's my opinion anyway.
  5. #44
    Sep 2009
    On a normal residential call I start out with a meter bag on my belt, a set of klein needle nose (with wire strippers), channel locks, small crescent, 1/4inch nut and 5/16 phillips and flat blade and gauges and flashlight. Sounds like a lot but it all fits in my back pocket amazingly. May not be a good habit but it's one I formed and for most light duty applications that gets the job done.
  6. #45
    State College, PA
    Quote Originally Posted by Diceman View Post
    Multi-tools are for HO and DIY'ers.
    Dice,
    You are a tool snob.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  7. #46
    I never used a 6n1 and always carried a half dozen klein screwdrivers until one day working on a roof i found this el cheapo orange handle screwdriver. I've used it everyday after that for about 15 years now.
    http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
  8. #47
    Jun 2009
    Lawng Eyeland
    Quote Originally Posted by BigMikeB View Post
    I like the Klein 11 in 1 myself, I threw that lenox POS off a roof a while back after losing the newly purchased replacement bits.
    I bought this 11in1 just because. It was like one better than 10in1. I truly did.
  9. #48
    Barrie, Ontario
    I carry one of these... Does everything I need it to do...
    Is this a Fabreze moment? C.Y.D. I'm voting white elephant. 2¢.
  10. #49
    Sep 2009
    hey
    klien rules...just buy 4 klien,,and dont worry...
  11. #50
    florida
    Who makes a good 4-in-1 screw driver...?
    No one.
    Educational forums are open.
  12. #51
    Oct 2007
    I would only buy the top manufactures klein, irwin, lenox, but the problem youll have is losing the bits or at least i do. But i still carry one. get you a flashlight holster and carry it on your belt be amazed how much time it will save you !
  13. #52
    Sep 2009
    S.C.
    I just scored a GreatNeck 4 in 1 screw-stick at the Black & Decker Outlet for $3.99. They also had drill/Nut driver assortments for nuts (1/4", 5/16" and 3/8") for .78 and three double ended drill/drivers (+ & -) for .78. Hey I splurged and got two each of the 78 cent deals. I was happier over the Black & Decker Drill/Nut drivers sets for .78 than the 4 in 1. The main reason I stopped by the outlet store was to see if they had any Dewalt... Not a one. They had some smokin' deals on Cheap A@@ FireStorm's!
    I'm looking for a 13 in 1... then, then all I'll need is a flash light!
