    Aug 2009
    Two Stage Furnace Setting
    I am considering purchasing an Amana AMV95, two stage, variable speed furnace. The first stage runs at about 70%. Can this be lowered to 40-50% and would this be advisable? Would it change the efficiency or be less comfortable? I ask because I have noticed that the more high end systems can run the first stage at 40%.
    I ask because it seems like this would provide more steady heat and less cycling.
    Thank you
    Nov 2008
    Chapel Hill, NC
    Most 2 stage furnaces run at about 70% on the first stage. I think you'll need a modulating furnace to get as low as 40%. I don't think you can adjust the two stage furnace output significantly.
    Cincinnati, Oh
    I've put in tons of amv9's with 2 stage, and you cant "turn it down". It's whatever amana has stage 1, and stage 2 set at. The only way to "adjust" it, would be doing something against the manufacture's suggestion.
    "Just get it done son."
    Dad adjusted
    If you want a lower percentage firing rate.
    You need to get a mod furnace. And Amana currently doesn't make one.
