Thread: Question for the Pros....
09-17-2009, 01:22 AM #1
New Guest
- Sep 2009
- Lexington, SC
- 1
I have a 10 year old Trane system. It is a 3.5 ton unit, 10 seer with a TWE042C14 air handler. The house was purchased with an unfinished room over the garage which has now been converted to a finished room. All in all, the house is now 2500 sq ft,(2000 before). I have a leak in the A-coil in the air handler which I have had techs out to service twice this year,(added 2 lbs first time and 1lb and a half second time). They say the coil is leaking due to rust and corrosion, the framework of the coil has some rust on it but they cannot pinpoint the leak. Now they haven't done a leak test..just used a sniffer to say "yes" theres a leak. Then they try to sell me a new system. The system cools fine as long as there freon in it.
Now my question is this:
Do I just need to get a replacement coil.
Or would it be time to upgrade my system to a higher SEER unit. Being that I finished the room over do I need to bump the system up to a 4 ton unit? That room does always seem to be a bit warmer in the summer and cooler in the winter.
I look forward to your thoughts.
Thanks,
Jon
09-17-2009, 01:34 AM #2
1) Yes, but I'd have someone pin point it first?
2) Yes, if your budget allows for it and you plan on living in your house for the life of the new system. Might as well take advantage of some of your tax dollars at work
3) Have a load calc done and see what you need with the addition, if you done other energy improvements to the house you might just need the air to be balanced properly, or you might be undersized or oversized with undersized ductwork or maybe leaky ductwork. Wont know till ya know!Global Warming or: None like it hot
No pleasure, no rapture, no exquisite sin greater... than central air. -Dogma
09-17-2009, 10:11 AM #3
It can be very difficult to pinpoint exactly where the coil is leaking. However if Halogen detector's sniff out refrigerant in the coil's compartment then it sounds like it's definately leaking.
Don't even hint to the tech. that a complete system replacement is an option. Simply ask for a quote to replace the leaking coil. Once you have this data you can explore all other options.
