    Oct 2007
    Southern Ontario
    accessing blower
    Just trying to find out before I get there... What do I have to do to get to the blower on a Continental freestanding gas stove....it appears that if i remove a bunch of screws from the rear cover it will come off, giving access. The blower is far behind the gas valve and up slightly.
    Virginia
    What model number?
    Oct 2007
    Southern Ontario
    m/n cdvs280-n... Always helps to know
    Nov 2005
    London, Ontario, Canada
    I hope by "rear cover" you mean on the inside. Open the glass door, take out the logs, and remove the screws along the fan panel edge, be sure to not lose any part of the gasket, install fan , test it , then put it back together with the gasket in place ( may need hi-temp silicone). On a side note that unit gets so hot that the fans last 2-4 years. Good luck!
    Virginia
    Here ya go page on 17, but natgastech seems to have done 1 or 2 in the past. :-) Let us know how much fun it was !!!
    http://www.continentalfireplaces.com...ls/CDVS280.pdf
    Oct 2007
    Southern Ontario
    Thanks for your time guys... especially the manual....I'm getting so excited already...customer every 2-4 years!
