Results 1 to 2 of 2
    Sep 2009
    Thumbs up Help! with Concord 80+ gas furnace
    ( Scratchin' my head )
    Details:
    Air-conditioning unit = outside Type: Goodman
    Furnace = in attic = Model: RGU80, RGH80, RGC80 per Manual
    Part No. 42457E097
    Furnace: Concord 80+ gas furnace
    __________________________________________________ _____________
    Problem:
    Air-conditioning worked fine, then stopped. Noticed
    that the ( t-stat ) was off, ( no LED )
    (t-state requires no battery's)
    Checked all circuite brakers, and actually swapped out the
    braker for the airconditioning unit at electrical panel.
    ( still no power to (t-stat) ) checked (t-stat) w/volt meter no power
    Next: checked all circuites with volt meter, everything has power.
    Checked power connection at furnace, and air-conditioning unit
    all show power going to units.
    ( Circuites are not tripping )
    Took off service panel of Concord 80+ furnace,
    (troubleshooting lights ( slowly flashing green in unisen )
    From the looks of it looks like the problem
    is from the furnace to the t-stat. ( no power from furance to t-stat)
    Looked for circuit braker on ( furnace control board ) and found
    none. actually looked all over furance for circuit breaker ( type found in car )
    and found nothing.
    ( please email me if you have information that could help )
    No email addresses in post
    Is there a reset on the furnace ?
    Any help is much appreciated.
    J in Cali.
    Call your local HVAC service contractor.
    Sorry, this is not a DIY site. So we are not allowed to give out DIY advise.
    Please read Site Rules Thank you.
    Thread closed.
