Results 1 to 13 of 21
Thread: 1 kW·h per hour just running fan
09-16-2009, 09:22 AM #1
- Jun 2009
- 146
Is it possible that just running the fan on my furnace is using 1 kW·h per hour? Last night before I went to bed, I checked the meter and let the fan run all night. To my surprise, 8 hours later the meter moved 8 kW·h.
I know we have other appliances that draw some energy when they are off (DVRs, computers, etc.), but I was surprised by this.
If it consumes this much energy just to run the fan on my furnace, I may end that practice altogether.
09-16-2009, 10:48 AM #2
Would depend, I normally figure .5kw per 24 but all electric using devises can vary. You got a fridge, hot water tank, security lights etc.? Turn off the blower and check it tonight.
09-16-2009, 10:50 AM #3
A gas furnace blower motor may run around 700-800 watts so you could round that up to 1 kw per hour. A VS blower running 1/2 speed for constant fan runs under .1 kw per hour by comparison. You may be surprised at how many items in your house are drawing power when off too.
09-16-2009, 10:51 AM #4
- Jun 2009
- 146
09-16-2009, 12:10 PM #5
If you have an electric water heater, it may have come on.
Your refrigerator most likely ran during the night.
09-16-2009, 02:10 PM #6
- Jan 2008
- 44
09-16-2009, 02:25 PM #7
A 1.5 hp motor is 1.12 Kw! I'm actually surprised that you didn't consume more than 1 kw a night considering computers, HotWater, TV's and wall warts. In most all new TV's the power supply is hot constantly.
09-16-2009, 04:02 PM #8
- Jun 2009
- 146
.. edit
09-16-2009, 04:03 PM #9
- Jun 2009
- 146
09-16-2009, 04:08 PM #10
- Jun 2009
- 146
My furnace is the Rheem RGRL-90. Can't find anywhere in the documentation how many watts it uses... I know it depends on a lot of things. The fan setting is on low, where I'm at about 1035 cfm based on my ESP.
http://globalimageserver.com/fetchDo...b-ef31233d6cbf
09-16-2009, 04:19 PM #11
09-16-2009, 04:45 PM #12
Per you info sheet, your blower is a 3/4 hp so the watts should be 560. I'm still thinking you're about where you should be. I haven't checked my Kw cost today but it was 8 or 9 cents a kw/h last time I looked (several years ago).
Going back to your sheet, they list the motor as 3/4 hp and then [559]
MOTOR H.P. [W]– SPEEDS–TYPE 3/4 [559]-4-PSC (copied and pasted from the sheet)
09-16-2009, 05:05 PM #13
- Jun 2009
- 146
