Results 14 to 19 of 19
    Dec 2008
    NW Iowa
    Quote Originally Posted by COOLJIM View Post
    just had a harvest fault, ice would not fall away from the plate . Found out it needs a new evap, as one of the horizontal bars has seperated from the evap plate , ice forms behind this loose bar and hangs on just will not release clean , a long harvest will give you a curve as the rear melts out , but the sheet is held in place by the seperated bar .
    I have had this also.
    May 2005
    lyting it was level, and the evap is made so its on a down hill anyway..
    cooljim, I've seen that on manotowacs..this one is in good shape..
    Let's give nukes a chance.
    Dec 2010
    Woodbridge Twp, NJ
    When you say the "back side", do you mean the cube side or the bridge side? A thick, curved bridge can be unit out of level but if it worked fine until recently, what happened, did someone move it? It can also be that the water inlet is leaking past and causing a thick bridge. Did you time the cycle? Freeze time on that should be about 12 min.
    Every customer you take for granted today will be someone else's tomorrow.
    Dec 2010
    Woodbridge Twp, NJ
    If you have a curved cube side, I would say your harvest is affected. Bad harvest solenoid, hot gas valve, scaled up evap,etc.
    May 2005
    dlz, the evaporator side of the cube...i talked with the factory about it and they said it was a bubble cause by the water flow..
    the one thing about this system is the blue paste that is in the water manifold..i was at this machine 3 months ago for a well needed cleaning
    today it looked like it hasn't been cleaned since new(09)..the bridge isn't over limit..i don't know what the customer was talking about.
    yes the time was 14 minutes if i helped the ice off.
    Dec 2010
    Woodbridge Twp, NJ
    You're right on the money. Freeze time can be between 12-16 minutes depending on water and ambient temp.
