Results 1 to 11 of 11
09-12-2009, 02:26 AM #1
- Sep 2009
- St. Paul, MN
- 4
Is this Bryant system matched ok?
Hi Everyone,
I got a quote today for replacement furnace and air conditoner. They are the following components and I am wondering if anyone could comment on whether it is all matched properly and also whether this model of air conditioner can be controled with the Evolution controller. Any opinions on upgrading that A/C to the Preffered series? Thanks!
Furnace: Bryant 355cav042060
Air Conditioner: Bryant 124ANA024
Evap coil: CNVP3017
Humidifier: Aprilaire AA600
Evolution Control
09-12-2009, 07:08 AM #2
Professional Member*
- Nov 2004
- SW FL
- 5,263
COMPLETE proposal needed
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
09-12-2009, 09:12 AM #3
- Mar 2006
- The South
- 1,852
yes as listed, this is an AHRI matched configuration.
3047932 Active Systems LEGACY 14 PURON AC BRYANT HEATING AND COOLING SYSTEMS 124ANA024-D CNPV*3017A** 355(A,C)AV042060 23200 13.00 16.00 1 RCU-A-CB 157 Yes
this condenser is the Legacy 14 and has good numbers. you might want to check the price difference for the Preferred 15 or new Preferred 17 AC condenser.
IMO
09-12-2009, 03:47 PM #4
- Sep 2009
- St. Paul, MN
- 4
Thanks for the responses.
From everything I have read though, it says that A/C cant be used with the Evolution controller. How does that work?
If they can somehow use it, what features/functionallity will I lose by not having an A/C that says its compatible with the evolution control?
09-12-2009, 11:22 PM #5
figure out the true match here:
http://www.ahridirectory.org/ahridir...ages/home.aspx
I'd strongly recommend a heat pump instead of a/c - even in Minnesota.
And Carrier/Bryant has a really cool water saver humidifier - get that too.Which makes more sense to you?
09-13-2009, 10:43 AM #6
What you were quoted has been a popular furnace and a/c combination for us this year. The Evolution control will not communicate with the air conditioiner, but you will still be able to use the control for advanced dehumidification.
The 165 is a great air conditioner as well. It operates a bit quieter, and gives status updates to the Evolution control.
Either way you will be happy with your new system.White Bear Township, Minnesota
www.summitheating.com
09-13-2009, 10:39 PM #7
- Sep 2009
- St. Paul, MN
- 4
Sorry to keep this going. I'm sure this is a stupid question but since the Evolution controller won't communicate with the air conditioner, does that mean I will have to have 2 thermostats or control panels or will the one evolution controller at least turn the a/c on and off?
Thanks!
09-13-2009, 10:41 PM #8
- Sep 2009
- St. Paul, MN
- 4
Thanks!
09-14-2009, 03:23 PM #9
- May 2007
- DC Metro area
- 3,223
The Evolution controller can be used with that outdoor unit, just won't communicate with diagnostics.
09-14-2009, 06:39 PM #10
- May 2008
- 8
Only the one Evolution control stat will be needed.
09-14-2009, 06:41 PM #11
- May 2008
- 8
And you will be happy with the system if it is installed correctly. I have installed several of these systems, and every customer has been impressed with them after the fact.
