Results 1 to 13 of 17
    DC Metro Area (MD)
    Do installers usually adjust the airflow?`
    Was wondering what the general consensus on this was, with input by both techs and installers. I was talking to someone I know who happens to do installs, and he didn't seem to realize the importance in adjusting anything from factory settings. An 80k/3 ton furnace with a 2 ton condenser would then be getting 600 cfm/ton (or whatever the ductwork would handle). He thinks of it as just airflow over the coil, and wouldn't bother adjusting anything. Is this usually the case you find? With variable speed blowers this would be especially important. That's why there are dipswitches. Makes me think twice about recommending a larger air handler for improved efficiency if its just going to be left at its 5 ton airflow setting, or whatever it may be, with a 3 ton condenser.
    SW FL
    Unhappy Depends on the Tech ... as always and ...
    You'll find many who can not discern the true
    differences between air, error and ear.
    Designer Dan
    I'll say none, if any. Unless they're told to. And how to do it. (not meant in an insulting way)
    From what we see, almost all are left on high for cooling. Every time we get a new installer he wonders why we take static readings and the install paperwork has instructions on speeds. Most are shocked if they are told to put a blower on low!
    Same here. Lots of blowers are left on high no matter what size A/C is installed.
    Myrtle Beach, SC
    However it comes from the factory is how it is left. I went on a survey two days ago and measured air flow. When I delivered the bid yesterday, He said I was the only one of 3 bidders who tested air flow.
    Our new power company program is going to require air flow testing. I am on the advisory board and have been pushing for that for years. November 1 it starts. Low interest loans and an up front rebate for the homeowner. The power company is going to provide training for the contractors who wish to be involved.
    Remember, Air Conditioning begins with AIR.
    Aug 2009
    Beatrice, NE
    We have a progran with the power co that gives a rebate to the customer only after the system is tested and adjusted to <10% of manufacturer rating. A power co rep told me that some of the dealers can't even fudge the number right. Go figure!!
    As for us we test and adjust every install!
    south louisiana
    I agree, most leave dipswitches on factory settings..even here where lowering the fan speed makes a dehumidification world of difference.
    too many folks think that variable speed is going to solve all the issues.
    its like this in many industries..foam insulation companies promise
    'total encapsulation systems', but do not test the jobs when completed..and want to argue with you when you do test.
    people have to have the want to do better, the ones who don't..make more work for those of us who do.
    good to see you Ryan...ever think about changing employment?
    as I seem to remember..you are a home owner who had to self educate to get a good
    install??
    SW FL
    Smile Nice to here about SOME Progrsss
    Quote Originally Posted by Kevin O'Neill View Post
    Power company is Progress Energy _ _ _ _ _?
    Designer Dan
    Myrtle Beach, SC
    Quote Originally Posted by dan sw fl View Post
    No Dan, It is Santee Cooper. But I understand that Progress Energy is bringing some similar programs back. But I don't work in their service areas.
    Rochester NY
    The customer generally gets what they pay for. Many homeowners go with low bid. Low bid generally means no heat loss, no blower door (so total guess at sizing), no mastic, slam the furnace in and go. Definitely no balancing - no time in the budget for that!
    Orphaned water heater? No worst case CAZ either.
    Another nice thing about the Infinity - tells you static and airflow at each stage.
    Southeast US
    A long time ago a misinformed guy, who was an otherwise excellent tech.....told me 'a little extra airflow won't hurt , it will help overcome the duct system'.
    Of course that's not what we want to do.
    Problem is...it blows the moisture off the coil..often creating MOLD. And more noise!
    in a house, Appomattox, Va.
    didn't first few yrs in install. wouldn't leave a job later w/o doing airflow as part of startup. Even when replace motor or feel there's and issue will check on service calls as well.
    Col 3:23
