Results 1 to 7 of 7
    Sep 2009
    Is my HTV Series a Carrier?
    I am in the middle of getting a unit installed, was told it was a Carrier unit (as was on the contract). The Installation, Operation, and Maintenance Manual that is here with the unit says Heat Controller (HTV Series). So, is this who makes the Carrier Unit? I'm afraid I am not getting what I paid for...
    I read the posts saying Climate Control makes Carrier, and Climate Control makes Heat Controller, but wasn't sure if that equated to Heat Controller = Carrier.
    Thanks!
    -T
    northern Indiana
    If you are talking Geothermal heat pump, Climate Master makes the units for Carrier
    Sep 2009
    Heat Controller
    So, since it says Heat Controller, it is NOT a Carrier?
    Climatemaster makes Heat Controller units too. However, you do not have a Carrier. Better ask the dealer what the skinny is. Could be that the wrong manual got in the unit. What does the unit say?
    Portland, OR
    What are the actual model and serial numbers on the unit?
    Correct Carriers watersource heat pumps are made by climatemaster
    Sep 2009
    heat controller
    It's an HTV 048.
